[gdal-dev] Re: GDAL 1.7 and GML3
Even Rouault
even.rouault at mines-paris.org
Mon May 24 08:43:52 EDT 2010
Jukka,
There's no ogr2ogr switch to control character encoding.
you didn't mention with which tool you tried to open the shapefiles. I suppose
it's not with OGR itself, as the shapefile driver does not do anything with
the encoding of the data it reads or writes. The issue is that it currently
writes DBF with LDID/87 (= 0x57, ANSI) whatever the encoding of the data is
really (so if UTF-8 data goes into this DBF and a software tries to interpret
it according to the LDID, it will read corrupted characters). There was
interest expressed on this mailing list the last few days for improved
encoding support (see
http://lists.osgeo.org/pipermail/gdal-dev/2010-May/024663.html)
This was also discussed here : http://trac.osgeo.org/gdal/ticket/3403
I can see different possibilities :
* use UTF-8 as pivot and transcode into/from it when reading/writing DBF.
Which would be consistant with
http://trac.osgeo.org/gdal/wiki/rfc23_ogr_unicode. A creation option would be
necessary to specify the target CPG/LDID.
* less ambitious : just use a creation option to specify the CPG/LDID of the
actual data passed without doing any transcoding.
The difference between the 2 options is conceptually a bit like -t_srs
and -a_srs
Le Monday 24 May 2010 14:16:07 Jukka Rahkonen, vous avez écrit :
> Even Rouault <even.rouault <at> mines-paris.org> writes:
> > Jukka,
> > In http://trac.osgeo.org/gdal/browser/trunk/autotest/ogr/ogr_gml_geom.py
> > , you can have an overview of a few GML 3 supported geometries.
> > The best is that you try and report what doesn't work so that it gets
> > possibly improved.
> Hi,
> I had a try with some feature types coming from Geoserver WFS 1.1.0.
> Ogr2ogr converts GML33 points, linestrings and multisurfaces (containing
> ->Polygons-> LinearRings) into shapefiles without problems.
> Our WFS is using UTF-8 encoding. When I open the shapefiles which I created
> with ogr2ogr all non-ASCII characters in my attributes look pretty odd. I
> can't find any switch in ogr2ogr for controlling character encoding. Is is
> somewhere hidden?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
