[gdal-dev] Using GDAL OGR DXF driver to export complex DXF
Blocks from Kosmo (OpenJUMP)
Andreas Neumann
a.neumann at carto.net
Wed Aug 17 09:24:37 EDT 2011
I don't know about Kosmo or OpenJump, but OGR supports export of
blocks. You would have to specify a separate template drawing containing
the block definitions.
Your input data would have to contain a column named "blockname", and
optionally columns "blockscale" and "blockangle".
blockname is a string corresponding to the block definitions in the
separate dxf template containing the block definitions, blockscale is in
syntax "(1,1,1)" for scaling in all three dimensions - "(1,1,1)"
actually does not scale as you would assume. block angle is in degrees I
think - I don't know which direction (clock-wise or anticlockwise and
starting point).
I successfully use OGR to convert a Postgis View to DXF on the command
line. This is for a waste-water network where we use blocks to symbolize
different manhole types. Here is the command I use:
ogr2ogr -f DXF test_ogr.dxf -dsco
header=header_export_werkplan_abwasser.dxf -spat 695700 245900 696000
246100 PG:"dbname='dbname' host='hostname' port='5432' user='www'
password='xxx' schemas=abwasser
tables=abwasser.export_dxf_geo405(the_geom)"
Hope this helps,
Andreas
On Wed, 17 Aug 2011 05:58:07 -0700 (PDT), rawcofe wrote:
> Hello,
> I'm wondering is it possible to use ogr dxf driver for exporting
> features as
> blocks in DXF format from Kosmo which is built on OpenJUMP framework?
> I have
> read (http://www.gdal.org/ogr/drv_dxf.html) that ogr dxf driver
> supports
> reading and writing of DXF blocks. Is the DXF driver completely
> functional
> considering block export and can be used with OpenJUMP as is or it
> requires
> a considerable amount of development effort to implement? Where can I
> download this driver and does it have some licensing issues if I try
> to
> integrate it with Kosmo?
> Thank you for your help,
> rawcofe
> http://osgeo-org.1803224.n2.nabble.com/Using-GDAL-OGR-DXF-driver-to-export-complex-DXF-Blocks-from-Kosmo-OpenJUMP-tp6695304p6695304.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
