[gdal-dev] Using GDAL OGR DXF driver to export complex DXF Blocks from Kosmo (OpenJUMP)
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Aug 17 09:26:15 EDT 2011
rawcofe,
This DXF driver is a part of the OGR library which comes with the GDAL
library.
To use it you have to import the whole OGR library. When you create code for
import/export of data from a different format using OGR, it can
import/export from all the formats supported by OGR [1].
OpenJUMP doesn't use GDAL. However, a plugin to use GDAL/OGR for
import/export of data could be very helpful. GDAL/OGR has java interface
[2].
First, checkout the ogr utilities [3].
[1]: http://www.gdal.org/ogr/ogr_formats.html
[2]: http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
[3]: http://www.gdal.org/ogr_utilities.html
On Wed, Aug 17, 2011 at 6:28 PM, rawcofe <rawcofe at gmail.com> wrote:
> Hello,
> I'm wondering is it possible to use ogr dxf driver for exporting features
> as
> blocks in DXF format from Kosmo which is built on OpenJUMP framework? I
> have
> read (http://www.gdal.org/ogr/drv_dxf.html) that ogr dxf driver supports
> reading and writing of DXF blocks. Is the DXF driver completely functional
> considering block export and can be used with OpenJUMP as is or it requires
> a considerable amount of development effort to implement? Where can I
> download this driver and does it have some licensing issues if I try to
> integrate it with Kosmo?
> Thank you for your help,
> rawcofe
> http://osgeo-org.1803224.n2.nabble.com/Using-GDAL-OGR-DXF-driver-to-export-complex-DXF-Blocks-from-Kosmo-OpenJUMP-tp6695304p6695304.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110817/9e06d1e9/attachment.html
