[gdal-dev] Re: Using GDAL OGR DXF driver to export complex DXF
Blocks from Kosmo (OpenJUMP)
rawcofe
rawcofe at gmail.com
Wed Aug 17 09:42:09 EDT 2011
Thank you very much for the quick answer guys, I will certainly try to go
deeply into the matter and come back with more questions if I run into some
problems.
Thanks once again,
rawcofe
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-GDAL-OGR-DXF-driver-to-export-complex-DXF-Blocks-from-Kosmo-OpenJUMP-tp6695304p6695462.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
