[gdal-dev] PDF via podofo
Even Rouault
even.rouault at mines-paris.org
Tue Jul 12 07:20:41 EDT 2011
Le mardi 12 juillet 2011 12:59:31, Joaquim Luis a écrit :
> Hi,
> I am still having troubles with a build with PDF support. I used to have
> a working solution for my gdalread MEX by using poppler 0.14, however
> now GDAL gives an error when linking with it (something about a member
> that does not exist).
Error at compile time about fillGooString() missing, with a very recent trunk ?
If so, I've just fixed it when testing compilation on CentOS 6 that ships with
poppler 0.12.4.
> So I turned again to 0.16 and managed to compile
> everything. But now Matlab just crash when I read a pdf (repeat, before
> it used to work).
Hum I guess you run into cross-heap issues related to different versions of the
MSVC Runtime...
> Next I tried the podofo (funny name) library. Everything compiles fine
> but a PDF driver does not exit when print the available drivers (and
> obviously, reading pdf does not work).
> I also noted that grepping "PODOFO_ENABLED" for the entire GDAL tree, it
> only shows up once, in nmake.opt.
Yes, there was something missing in frmts/makefile.vc. I think I've just fixed
it (untested though)
So 'svn update' and retry
> Ah, it's a Windows build that I'm talking about.
> Joaquim Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
