[gdal-dev] building GDAL for Java with ECW support
Even Rouault even.rouault at mines-paris.org
Sun Jul 24 17:07:43 EDT 2011
Le dimanche 24 juillet 2011 21:15:40, alxster a écrit :
> Hi,
> I am completely new in compiling in C/C++
> I am using MingW/MSYS as for instructions in
> http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
> For first I downloaded ERDAS SDK and tried to enable ECW support as in
> http://trac.osgeo.org/gdal/wiki/ECW
I don't think it is possible to have ECW support with MinGW, because the ECW
SDK has MSVC .lib that can't be turned into a GCC import library .a
> But support is still disabled.
> on this newsletter arc I've found just old posts with broken links.
> Is there any uptated tutorial (as easy as possible) to build a win32
> gdal.dll to be used by gdal.jar Java JNI, with ECW support?
> thanks
> http://osgeo-org.1803224.n2.nabble.com/building-GDAL-for-Java-with-ECW-sup
> port-tp6616111p6616111.html Sent from the GDAL - Dev mailing list archive
> at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
