[gdal-dev] building GDAL for Java with ECW support
Nicolas Simon nicolas.simon at spw.wallonie.be
Mon Jul 25 04:00:00 EDT 2011
	Concerning convertion from MSVC .lib to GCC import library .a,
      help could by find here
	http://jrfonseca.planetaclix.pt/projects/gnu-win32/software/reimp/index.html
	Nicolas
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org]De la part de Even Rouault
> Envoyé : dimanche 24 juillet 2011 23:08
> À : gdal-dev at lists.osgeo.org
> Cc : alxster
> Objet : Re: [gdal-dev] building GDAL for Java with ECW support
> Le dimanche 24 juillet 2011 21:15:40, alxster a écrit :
> > Hi,
> > I am completely new in compiling in C/C++
> > I am using MingW/MSYS as for instructions in
> > http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
> > For first I downloaded ERDAS SDK and tried to enable ECW
> support as in
> > http://trac.osgeo.org/gdal/wiki/ECW
> I don't think it is possible to have ECW support with MinGW,
> because the ECW
> SDK has MSVC .lib that can't be turned into a GCC import library .a
> > But support is still disabled.
> > on this newsletter arc I've found just old posts with broken links.
> > Is there any uptated tutorial (as easy as possible) to build a win32
> > gdal.dll to be used by gdal.jar Java JNI, with ECW support?
> > thanks
> > View this message in context:
http://osgeo-org.1803224.n2.nabble.com/building-GDAL-for-Java-with-ECW-sup
> port-tp6616111p6616111.html Sent from the GDAL - Dev mailing list archive
> at Nabble.com.
> gdal-dev mailing list
