[gdal-dev] building GDAL for Java with ECW support
Even Rouault
even.rouault at mines-paris.org
Mon Jul 25 05:46:08 EDT 2011
Selon Nicolas Simon <nicolas.simon at spw.wallonie.be>:
> Hi,
> Concerning convertion from MSVC .lib to GCC import library .a,
> help could by find here
> http://jrfonseca.planetaclix.pt/projects/gnu-win32/software/reimp/index.html
Yes I know reimp, but AFAIR, it doesn't work well with C++ symbols, which the
ECW SDK contains. Perhaps this has improved, but I wouldn't be too optimistic.
Anyway the freely downloadable Visual Studio Express might be a better starting
point. GDAL can be built with it.
And/or start from Tamas Szekeres daily builds and customize them (there are
source packages) to your needs.
> Nicolas
> > -----Message d'origine-----
> > De : gdal-dev-bounces at lists.osgeo.org
> > [mailto:gdal-dev-bounces at lists.osgeo.org]De la part de Even Rouault
> > Envoyé : dimanche 24 juillet 2011 23:08
> > À : gdal-dev at lists.osgeo.org
> > Cc : alxster
> > Objet : Re: [gdal-dev] building GDAL for Java with ECW support
> > Le dimanche 24 juillet 2011 21:15:40, alxster a écrit :
> > > Hi,
> > > I am completely new in compiling in C/C++
> > > I am using MingW/MSYS as for instructions in
> > > http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
> > > For first I downloaded ERDAS SDK and tried to enable ECW
> > support as in
> > > http://trac.osgeo.org/gdal/wiki/ECW
> > I don't think it is possible to have ECW support with MinGW,
> > because the ECW
> > SDK has MSVC .lib that can't be turned into a GCC import library .a
> > > But support is still disabled.
> > > on this newsletter arc I've found just old posts with broken links.
> > > Is there any uptated tutorial (as easy as possible) to build a win32
> > > gdal.dll to be used by gdal.jar Java JNI, with ECW support?
> > > thanks
> > > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/building-GDAL-for-Java-with-ECW-sup
> > port-tp6616111p6616111.html Sent from the GDAL - Dev mailing list archive
> > at Nabble.com.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
