[gdal-dev] KMLSuperOverlay in Google Earth 6.1.0.5001
Even Rouault even.rouault at mines-paris.org
Fri Nov 18 14:11:28 EST 2011
Le vendredi 18 novembre 2011 20:04:13, Kyle Shannon a écrit :
> I doubt they will change the spec, and I am sure you are right about the
> many bad files.  I imagine that most people just checked the output from
> his or her program in google earth and said "Good enough".  If no one gets
> around to it before I get off work and to a *nix workstation, I will file
> a ticket and a patch.  It is probably safe to backport to 1.8 as well.
I was just looking at this. I'll notify you of the ticket when done. Testing
will be welcome because I have a much older GE version.
