[gdal-dev] Help on GDAL 1.8.1 .dll files for C#
Armin Burger
armin.burger at gmx.net
Sun Oct 2 18:12:07 EDT 2011
Zhenyu,
have you tried the compiled versions from
http://www.gisinternals.com/sdk/
they come in various flavours of compilers, in 32/64 bit, contain java,
python and c# bindings. So I guess one of them should fit your environment.
Best regards
armin
On 02/10/2011 23:01, Zhenyu Lu wrote:
> Hi,
> Is there any possibilities that any kind-hearted guys can send me the
> compiled .dll files of GDAL 1.8.1 for C#. I am trying to compile these
> .dll files this whole afternoon, but failed all the time.
> I used to create tools using GDAL 1.5.2 and C#. These tools run well
> under the OS of XP, but these days I would like to run the tools under
> the Windows 7. It always remind me that "initialize the OSGeo.GDAL.Gdal
> throw an exception".
> I am guessing is that because the 1.5.2 is too old to work on Windows 7.
> Then I decided to compile the most current version of GDAL 1.8.1 to see
> whether it will be useful for solving the problem. I have already
> obtained three .dll files for GDAL, which are gdal18, gdal_wrap,
> gdal_csharp. But I noticed that two files named as gdalconst_csharp.dll
> and gdalconst_wrap.dll are missing. Does the GDAL 1.8.1 require
> same .dll files as the GDAL 1.5.2?
> Anyone send me the compiled .dll files or let me know where the possible
> problem would be might save my frustrated life ^-^.
> Thanks in advance for whoever can help!
> Zhenyu Lu
> SUNY-ESF
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
