[gdal-dev] Re: Question regarding GDAL .dll files for C#
Tamas Szekeres
szekerest at gmail.com
Mon Oct 3 03:04:36 EDT 2011
Hi Zhenyu Lu,
You need not install the plugin dll-s if you don't require the corresponding
functionality.
With regards to the dependent dll-s, you can use the -dev packages from
http://www.gisinternals.com/sdk/ to compile your own versions using the
following steps:
1. Download the -dev package according to your compiler version.
2. Extract the SDK files in a specific directory (like C:\builds)
3. Check out the gdal sources into this directory.
4. Edit makefile and comment out the unwanted dependecies, like:
#GDAL_POSTGIS = YES
5. Open a Visual studio command prompt, and type:
nmake gdal GDAL_DIR=[your gdal directory]
Best regards,
Tamas
2011/10/3 Zhenyu Lu <luzhenyu1981 at gmail.com>
> Hi Tamas,
> Sorry for sending you email so late at night. I noticed that you're in
> charge of maintaining the GDAL binary and SDK packages. I would say that
> you've done a fatastic job so far for making so many GDAL binary and SDK
> packages. I've downloaded two .msi files which worked great. So I'm thinking
> that your knowledge might offer huge help for me.
> I would like to ask you several questions regarding the binary and SDK
> packages you've released.
> I used to use the .dll files of GDAL 1.5.2 before, which were compiled by
> myself using VS2005. Now I wrote a tool for students to use for their labs.
> I suddenly realized that all the computers of my uniersity have installed
> Windows 7 64bit operating system, and my previous compiled .dll files do not
> work anymore.
> So I downloaded the gdal-18-1400-x64-core.msi and installed it on
> my computer. Compared with the previous .dll files, the newly created .dll
> files has much larger size (maybe much more functions). I think it is mainly
> because I must include some other .dll files (hdf5dll, geos_c, libmysql,
> pdflib, and xerces-c_2_8.dll) to make it work. However, using my previously
> compiled .dll file, I only need to include the gdal1.5.dll itself. So my
> previous implementation has the file size of < 5 MB, but now the
> implementation grows to more than 20 MB which make it hard to distribute.
> Now I would like to ask is it possible for you to create .dll files or the
> installation file to only include the gdal18.dll file without the other
> plugin .dll files? Or is there a way for me to create such .dll files?
> Hopefully I have made my questions straightforward.
> Thank you so much if you could offer me some suggestions.
> -- Zhenyu Lu
> SUNY-ESF
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111003/a01fdbe5/attachment.html
