[gdal-dev] Postgis Raster driver improvements.
Jorge Arévalo jorge.arevalo at deimos-space.com
Wed Feb 22 05:54:39 EST 2012
Hello,
I confirm the driver is called "PostGIS Raster" instead of "WKT
Raster". The old name just remains in testing scripts. The rest is ok.
And I'm in contact with David for everything related with the driver.
Best regards,
Jorge
On Tue, Feb 21, 2012 at 10:48 PM, David Zwarg <dzwarg+gdal at azavea.com> wrote:
> Hi Frank,
> Yes, I am modernizing some of the testing scripts for PostGISRaster, and
> adding write support in the near future.  I've been in touch with and am
> coordinating with Jorge.
> I think it was just the test script that used the old name, btw. The driver
> is truly called "PostGISRaster", just the test script wasn't up-to-date.
> Thanks,
> Zwarg
> On Tue, Feb 21, 2012 at 2:19 PM, Frank Warmerdam <warmerdam at pobox.com>
> wrote:
>> On Tue, Feb 21, 2012 at 10:38 AM, David Zwarg <dzwarg+gdal at azavea.com>
>> wrote:
>> > Hello,
>> > I would like to help add write support and more to the Postgis Raster
>> > driver.  Currently, there is a loader script in the autotest/data
>> > directory
>> > for the driver -- when write support is complete, will that script no
>> > longer
>> > be necessary? I don't see any corresponding test loading scripts for any
>> > of
>> > the other types of drivers.
>> > Also, in many places the driver is "WKTRaster" -- would it be possible
>> > to
>> > update the name of the driver to PostgisRaster, or pgRaster, or
>> > something
>> > similar? WKTRaster was the name of the spike branch, but raster support
>> > was
>> > renamed from WKTRaster when it was brought into Postgis trunk.
>> David,
>> Renaming the driver at this point should be ok.  The
>> driver name is mainly used for creation operations so
>> if we don't yet support creation it isn't going to break
>> existing scripts when it changes.
>> If it would break a lot of stuff, I'd have suggested registering
>> it twice - once under each name.
>> I'm looking forward to improvements.  I presume you are
>> in communication with Jorge who has done most of the
>> previous work, right?  I think he mentioned the two of you
>> are collaborating.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Jorge Arévalo
Internet & Mobility Division, DEIMOS
http://mobility.grupodeimos.com/
http://www.libregis.org
http://geohash.org/ezjqgrgzz0g
