[gdal-dev] gdalsrsinfo "ERROR - failed to load SRS definition"
Etienne Tourigny
etourigny.dev at gmail.com
Mon Jul 30 08:40:13 PDT 2012
There might be an other tool that can translate WKT or PROJ.4 strings
to/from GML CRS definition?
Etienne
On Mon, Jul 30, 2012 at 12:28 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Selon Piero Campalani <piero.campa at gmail.com>:
>> Thanks Even,
>> I suspected this, GML is still not that widely used for CRS definition
>> seemingly.
>> Unluckily I have strong reasons to use GML, so do you know if there are is
>> some developing in progress to support a wider range of projections from/to
>> the XML representation?
> Not that I'm aware of. The last significant work in that area of OSR dates back
> to more than 6 years ago.
> From what I see from the code, adding new projections should be doable, but as
> this is rather a boring task, it would help if you could identify the
> projections methods that are the most common. Are you trying to be interoperable
> with another software, or is it just GDAL/GDAL interoperability ? Having
> GDAL/GDAL interoperability is easy, but making sure it works properly with other
> software is less obvious.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
