[gdal-dev] OGR 1.9.0 won't open DGN file
Zoltan Szecsei
zoltans at geograph.co.za
Wed Jun 20 01:53:46 PDT 2012
I have some DGN v7 files with contours, and I wish to add up the total
length of all the contours in the file.
Using:
zls at gs0:~/ngi10k/ngi10k_geo$ ogrinfo --version
GDAL 1.9.0, released 2011/12/29
I get:
zls at gs0:~/ngi10k/ngi10k_geo$ ogrinfo 3117bb_lin_v7.dgn
INFO: Open of `3117bb_lin_v7.dgn'
using driver `DGN' successful.
1: elements
If I use parameters -so or -q or -geom=SUMMARY then I get the same
error, but if I use parameter -al, then the DGN file is opened and all
24000 contours are dumped to stdout.
QGIS 1.7.3 on Windows does open the same DGN file.
How can I investigate further as to why Linux ogr won't open the file
using ?
TIA,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897 Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
