[gdal-dev] GDAL/OGR 1.10.0 Release Candidate 3 available
maning sambale
emmanuel.sambale at gmail.com
Thu Apr 18 19:46:21 PDT 2013
Dear Even,
On Fri, Apr 19, 2013 at 4:26 AM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> #5056: OSM waterway
One issue with adding waterway as lines is that the tag
waterway=riverbank is usually for polygon and multi-polygons
(relations).
Is there a way within the osmconf.ini for instance to limit to a
specific key:value pair like waterway=riverbank as multipolygon?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
