[gdal-dev] ESRI binary grid (.hdr)
Even Rouault even.rouault at mines-paris.org
Wed Feb 27 05:33:29 PST 2013
Le mercredi 27 février 2013 13:03:03, SBL a écrit :
> Hi,
> I have numerous ESRI binary grids in hdr labled format (one .hdr and one
> .bil file for each dataset) which I would like to load into GRASS using
> r.in.gdal.
> There i get the following error-messages:
> "ERROR 3: Failed to read scanline 775."
> and
> "ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 775"
> I get the same error-messages when using gdal_translate or (for example)
> gdalinfo -stats on the datasets.
> In ArcGIS I can convert the data to a different format, so I suspect there
> must be something with GDAL. Any ideas?
The best would be to open a GDAL Trac ticket with the .hdr and .bil attached
to it.
> Thanks in advance.
> Stefan
> http://osgeo-org.1560.n6.nabble.com/ESRI-binary-grid-hdr-tp5037238.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
