[gdal-dev] Colors and KML output
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Oct 30 06:36:43 PDT 2013
Tim Keitt <tkeitt <at> utexas.edu> writes:
> Brilliant. That works. The problem was that I was using the -sql switch to
query from postgis directly into KML. Apparently that does not work at lest
with my query string. Dumping with psql2shape and then ogr2ogr to convert to
KML did the trick. Thanks.
> Now to figure out how to switch the drawing order...
That's a good start but it may be better to learn how to play with VRT files
with some -sql inside. This document is somehow related
http://latuviitta.org/documents/Geospatial_PDF_maps_from_OSM_with_GDAL.pdf
-Jukka-
