[gdal-dev] WMS Issues Two Requests
Even Rouault even.rouault at mines-paris.org
Mon Feb 10 04:18:51 PST 2014
Selon Martin Lewis <MLewis at ngms.eu.com>:
> Unfortunately. Even, 'that's life' in my customers world was too slow.
I didn't imply that you had to bear poor performance. For higher performance,
other protocols, tile-oriented and cache friendly, are more appropriate such as
WMTS, TMS.
> Now I understand what the WMS driver is doing in terms of BlockSize and
> DataWindow, I can work round the issue for the time being by requesting a
> data window sized block in a single request rather than lots of smaller
> blocks in several requests.
> This has effectively speeded up the user interaction from about 5 secs to
> 1-2 secs, an acceptable delay when navigating around a map.
> Thanks
> Martin
http://osgeo-org.1560.x6.nabble.com/Re-WMS-Issues-Two-Requests-tp5102423p5102848.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
