[gdal-dev] GDAL 1.11 release plan
Olivier BARTHELEMY
barthelemy at geovariances.com
Wed Mar 26 02:34:27 PDT 2014
Here is what cppcheck 1.64 reports as 'errors' in gdal-1.10.1:
[frmts\adrg\adrgdataset.cpp:1071]: (error) Memory leak: TILEINDEX
[frmts\coasp\coasp_dataset.cpp:199]: (error) Undefined behavior: Variable
'pszItemValue' is used as parameter and destination in s[n]printf().
[frmts\dted\dted_create.c:181]: (error) Resource leak: fp
[frmts\envisat\EnvisatFile.c:286]: (error) Memory leak: self
[frmts\envisat\EnvisatFile.c:609]: (error) Memory leak: dsd_text
[frmts\envisat\EnvisatFile.c:1776]: (error) Memory leak: entry
[frmts\georaster\georaster_dataset.cpp:188]: (error) Possible null pointer
dereference: poGRD
[frmts\georaster\georaster_dataset.cpp:189]: (error) Possible null pointer
dereference: poGRD
[frmts\georaster\georaster_dataset.cpp:190]: (error) Possible null pointer
dereference: poGRD
[frmts\georaster\georaster_dataset.cpp:191]: (error) Possible null pointer
dereference: poGRD
[frmts\georaster\oci_wrapper.cpp:1590]: (error) Pointer to local array
variable returned.
[frmts\gif\giflib\gifalloc.c:67]: (error) Memory leak: Object
[frmts\grib\degrib18\degrib\clock.c:2071]: (error) Common realloc mistake:
'Stack' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\clock.c:2175]: (error) Common realloc mistake:
'Rel' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\clock.c:2197]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\clock.c:2209]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\grib2api.c:594]: (error) Uninitialized
variable: igdstmpl
[frmts\grib\degrib18\degrib\metaparse.cpp:2628]: (error) Common realloc
mistake: 'freq' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\myerror.c:109]: (error) Common realloc mistake:
'buffer' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\myerror.c:126]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:132]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:149]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:158]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:187]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:195]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:203]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:211]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:218]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:229]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:241]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:257]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myerror.c:442]: (error) Common realloc mistake:
'preBuffer' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\myerror.c:534]: (error) Common realloc mistake:
'buff' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\myutil.c:85]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myutil.c:92]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myutil.c:99]: (error) Common realloc mistake:
[frmts\grib\degrib18\degrib\myutil.c:149]: (error) Common realloc mistake:
'argv' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\tdlpack.cpp:3256]: (error) Common realloc
mistake: 'subGroup' nulled but not freed upon failure
[frmts\grib\degrib18\degrib\tdlpack.cpp:4179]: (error) Read and write
operations without a call to a positioning function (fseek, fsetpos or
rewind) or fflush in between result in undefined behaviour.
[frmts\grib\degrib18\g2clib-1.0.4\compack.c:159]: (error) Uninitialized
variable: ival1
[frmts\grib\degrib18\g2clib-1.0.4\comunpack.c:198]: (error) Memory leak:
ifld
[frmts\grib\degrib18\g2clib-1.0.4\misspack.c:203]: (error) Uninitialized
variable: ival1
[frmts\grib\degrib18\g2clib-1.0.4\misspack.c:118]: (error) Uninitialized
variable: rmisss
[frmts\grib\degrib18\g2clib-1.0.4\pngunpack.c:61]: (error) Memory leak: ifld
ctemp
[frmts\hdf4\hdf-eos\EHapi.c:2315]: (error) Common realloc mistake:
'metabuf' nulled but not freed upon failure
[frmts\hdf4\hdf-eos\EHapi.c:3665]: (error) Common realloc mistake:
'EHXtypeTable' nulled but not freed upon failure
[frmts\hdf4\hdf-eos\EHapi.c:3668]: (error) Common realloc mistake:
'EHXacsTable' nulled but not freed upon failure
[frmts\hdf4\hdf-eos\EHapi.c:3671]: (error) Common realloc mistake:
'EHXfidTable' nulled but not freed upon failure
[frmts\hdf4\hdf-eos\EHapi.c:3674]: (error) Common realloc mistake:
'EHXsdTable' nulled but not freed upon failure
[frmts\hdf4\hdf-eos\GDapi.c:2411]: (error) Array 'HDFcomp[5]' accessed at
index 19, which is out of bounds.
[frmts\hdf4\hdf-eos\GDapi.c:2177]: (error) Array 'originNames[4]' accessed
at index 15, which is out of bounds.
[frmts\hdf4\hdf-eos\GDapi.c:2292]: (error) Array 'pixregNames[2]' accessed
at index 7, which is out of bounds.
[frmts\hdf4\hdf-eos\SWapi.c:4995]: (error) Memory leak: fillbuf
[frmts\hdf4\hdf-eos\SWapi.c:5615]: (error) Memory leak: flag
[frmts\hdf4\hdf-eos\SWapi.c:6239]: (error) Memory leak: flag
[frmts\idrisi\IdrisiDataset.cpp:1886]: (error) syntax error
[frmts\ilwis\ilwisdataset.cpp:1425]: (error) syntax error
[frmts\msg\msgdataset.cpp:532]: (error) Object pointed by an 'auto_ptr' is
destroyed using operator 'delete'. You should not use 'auto_ptr' for
pointers obtained with operator 'new[]'.
[frmts\netcdf\netcdfdataset.cpp:5997]: (error) Uninitialized variable:
strtime
[frmts\pcidsk\sdk\core\pcidsk_utils.cpp:644]: (error) Common realloc
mistake: 'pszWorkBuffer' nulled but not freed upon failure
[frmts\pcidsk\sdk\core\pcidskexception.cpp:170]: (error) Common realloc
[frmts\png\libpng\pngrutil.c:996]: (error) Uninitialized variable: igamma
[frmts\rasterlite\rasterlitedataset.cpp:1179]: (error) Possible null
pointer dereference: poDS
[frmts\rasterlite\rasterlitedataset.cpp:1185]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1186]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1187]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1188]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1190]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1191]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1192]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1193]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1194]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1195]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1196]: (error) Possible null
[frmts\rasterlite\rasterlitedataset.cpp:1267]: (error) Possible null
[frmts\raw\atlsci_spheroid.cpp:122]: (error) syntax error
[frmts\raw\mffdataset.cpp:1451]: (error) syntax error
[frmts\sgi\sgidataset.cpp:523]: (error) Using 'memcpy' on struct that
contains a 'std::string'.
[ogr\ogrsf_frmts\dgn\dgnhelp.cpp:1379]: (error) syntax error
[ogr\ogrsf_frmts\dwg\ogrdwglayer.cpp:323]: (error) Invalid number of
character ({) when these macros are defined: 'notdef'.
[ogr\ogrsf_frmts\filegdb\FGdbLayer.cpp:1914]: (error) syntax error
[ogr\ogrsf_frmts\generic\ogrdatasource.cpp:1425]: (error) Possible null
pointer dereference: papoSrcLayers
[ogr\ogrsf_frmts\mitab\mitab_coordsys.cpp:747]: (error) Buffer is accessed
out of bounds.
[ogr\ogrsf_frmts\mitab\mitab_geometry.cpp:223]: (error) Memory leak:
xintersect
[ogr\ogrsf_frmts\ntf\ntffilereader.cpp:260]: (error) Memory pointed to by
'poRecord' is freed twice.
[ogr\ogrsf_frmts\pg\ogrpgdatasource.cpp:1102]: (error) Memory leak: poLayer
[ogr\ogrsf_frmts\shape\shptree.c:241]: (error) Memory leak: psTree
[port\cpl_minizip_zip.cpp:608]: (error) Memory leak: zi
[port\cpl_strtod.cpp:67]: (error) Division by zero.
I'd be happy to provide fix patches, but i have not much time at the
moment, so it won't be before a 1.11 release.
If you want to see the other 'warnings', and get un updated report on GDAL
trunk, maybe you could ask to those who manage
http://debbie.postgis.net:8080/view/GDAL/ to add the cppcheck plugin to
their Jenkins?
2014-03-26 9:15 GMT+01:00 Even Rouault <even.rouault at mines-paris.org>:
> Hi Olivier,
> If you could share with us the errors that have been reported (and the
> options
> you have used to pass cppcheck on GDAL source), that would be a good
> contribution. Even better if you can submit a patch to fix them ;-)
> Not saying they shouldn't be fixed, but I don't see that as a blocker point
> however, unless they show up in nominal code paths. They have likely
> existed for
> years.
> We also have registered GDAL to the Coverity scanner, and we try to fix
> errors
> that are reported in new code.
> Even
> > I think you should take a look at what cppcheck finds when scanning GDAL
> > source before the next release. There are a few tens of small errors.
> > Mostly, small leaks in particalr cases. Not very important errors, but
> that
> > ought to be fixed before doing an release in my opinion
> > 2014-03-26 8:49 GMT+01:00 Paul Meems <bontepaarden at gmail.com>:
> > > +1 for adding VS2013 binaries in GISInternals
> > > Thanks,
> > > Paul
> > > *Paul Meems *
> > > Release manager, configuration manager
> > > and forum moderator of MapWindow GIS.
> > > www.mapwindow.org
> > > Owner of MapWindow.nl - Support for
> > > Dutch speaking users.
> > > www.mapwindow.nl
> > > *Join us at the MapWindow GIS Conference 2014
> > > <http://geogis.detek.unideb.hu/TKonferencia/2014/>, in Debrecen
> Hungary*
> > > 2014-03-26 6:25 GMT+01:00 xavier lhomme <lhomme.xavier at gmail.com>:
> > > Hi
> > >> Adding Visual Studio 2012 2013 in GISInternals for Gdal 1.11 should
> be
> > >> great too.
> > >> Xav
> > >> Le 25 mars 2014 22:57, "Tamas Szekeres" <szekerest at gmail.com> a
> écrit :
> > >> That sounds good to me.
> > >>> Best regards,
> > >>> Tamas
> > >>> 2014-03-25 22:37 GMT+01:00 Even Rouault <
> > >>>> Hi,
> > >>>> GDAL 1.10 was released about one year ago, so it is time to think
> about
> > >>>> the next
> > >>>> release. I think we should just call it 1.11 given that there are no
> > >>>> major
> > >>>> architectural changes (although there have been non trivial changes
> in
> > >>>> RAT
> > >>>> management and for multiple geometry field support, but that only
> > >>>> impacts core &
> > >>>> drivers), and the C API and ABI is still preserved (for those who
> have
> > >>>> looked at
> > >>>> the other thread, my experiments on unification are *not* in trunk).
> > >>>> For the
> > >>>> details, I have initiated the preliminary NEWS :
> > >>>> http://trac.osgeo.org/gdal/export/27091/trunk/gdal/NEWS (*)
> > >>>> There are some mentions to 2.0 in the documentation of new features,
> > >>>> but I'll
> > >>>> end up fixing them to reflect the 1.11 numbering.
> > >>>> I think we are in a good shape to start the beta phase soon. If
> people
> > >>>> have
> > >>>> features or bug fixes almost ready that they'd like to be in 1.11,
> > >>>> please speak
> > >>>> up now. Otherwise I suggest issuing a beta-1 at the end of next
> week,
> > >>>> give it a
> > >>>> week for testing, and depending on the outcome, issue a beta-2, or
> just
> > >>>> try
> > >>>> RC-1. Unless someone volunteers (the process is fairly well
> documented
> > >>>> in
> > >>>> HOWTO-RELEASE), I can be release manager for 1.11.
> > >>>> Any opinion about that plan ?
> > >>>> Best regards,
> > >>>> Even
> > >>>> Geospatial professional services
> > >>>> http://even.rouault.free.fr/services.html
> > >>>> _______________________________________________
> > >>>> gdal-dev mailing list
> > >>>> gdal-dev at lists.osgeo.org
> > >>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > [image: Geovariances]
> > Olivier BARTHELEMY *Software development engineer*
> > Geovariances, 49bis avenue Franklin Roosevelt - 77215 AVON CEDEX - FRANCE
> > | www.geovariances.com <http://link.geovariances.com/eml-home>
> > Keep posted about Geovariances <
> http://link.geovariances.com/eml-geowidget>
> > <http://link.geovariances.com/eml-linkedin-gv>
> > <http://link.geovariances.com/eml-linkedin>
> > <http://link.geovariances.com/eml-twitter>
> > <http://link.geovariances.com/eml-youtube>
> > <http://link.geovariances.com/eml-slideshare>
Keep posted about Geovariances <http://link.geovariances.com/eml-geowidget>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140326/cb6d9d19/attachment-0001.html>
