[gdal-dev] building interface to org2org
Nick Ves
vesnikos at gmail.com
Mon Apr 20 03:06:05 PDT 2015
You can try ogr2gui. I haven't used it tho. Give it a spin and
afterwards if you want you can tell us if its any good.
http://www.ogr2gui.ca/en/index.php
On Mon, Apr 20, 2015 at 1:01 PM, Błażej Doruch <blazej.doruch at gmail.com> wrote:
> ...but in QGIS, and also new version of FWtools 2.4.7 it's some kind of
> mistake in transformation beetween EPSG:2175 and 2175 (about 40 meters
> displacement)
> that's why I must use older version - FWtools 1.3.5 .
> And the second reason why I want to do it is that in QGIS as I know there is
> no multiple file transformation option.
> Blaze
> 2015-04-20 11:06 GMT+02:00 Eloi <eloi at openmailbox.org>:
>> On 2015-04-20 10:20, Błażej Doruch wrote:
>>> Has anybody make program which implement org2org,
>>> I need to have such functionality:
>>> -select file (files) to convert;
>>> -select type of conversion (source and destination EPSG- only
>>> 2175-2177 (both ways));
>>> -select type of file format;
>>> -make conversion;
>> QGIS.
>> http://qgis.org
>> Eloi Ribeiro
>> Geoinformatic
>> 51.9871, 5.6661
>> http://eloiribeiro.eu (home server, probably down o_O)
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Błażej Doruch
