[gdal-dev] HDF support under Gentoo/Funtoo
Sebastian Walter
sebastian.walter at fu-berlin.de
Mon Feb 16 06:33:37 PST 2015
Hi Nikos,
The gentoo ebuild is somehow limited in terms of driver choices in my
opinion (especially if you have additional commercial licenses to
include as, e.g. Kakadu or ECW). What I do is to compile a custom gdal
build and install it to /usr/local. For the current stable 1.11, you
would emerge sci-libs/hdf first, and then configure the downloaded
package like this:
./configure --prefix=/usr/local --with-python
(both HDF libs are found automatically by configure).
Cheers, Sebastian
On 02/16/15 10:23, Nikos Alexandris wrote:
> Greetings to the list.
> I am trying to emerge gdal under Funtoo with support for HDF4 (see
> <http://gpo.zugaina.org/sci-libs/gdal> for the ebuild). I am not sure
> how to get this done. There is no USE flag for hdf (only for hdf5).
> Since the system is quite similar with Gentoo, is there anyone out there
> working with gdal and support for HDF4 under Gentoo?
> The instructions at <https://trac.osgeo.org/gdal/wiki/HDF> don't help me
> much either. I only understand as a relevant information the part about
> "Incompatibility with NetCDF Libraries". But I don't request support
> for NetCDF via the respective use flag.
> Thank you, Nikos
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150216/2e4456ec/attachment-0001.bin>
