[gdal-dev] Can I interpret GIBS ASTER_GDEM_Color_Index as elevation somehow?
Carl Godkin
cgodkin at gmail.com
Mon Jul 13 06:32:18 PDT 2015
Hi again,
I'm interested in trying to use the "Script-level Access via GDAL" guidance
on the NASA "GIBS API for Developers" page:
https://wiki.earthdata.nasa.gov/display/GIBS/GIBS+API+for+Developers
The layer I'm interested in is "ASTER_GDEM_Color_Index" which is elevation
data.
The site contains advice on how to customize a WMS service description file
for the multitude of data types offered and I came up with this:
<GDAL_WMS>
<Service name="TMS">
<ServerUrl>
http://map1.vis.earthdata.nasa.gov/wmts-geo/ASTER_GDEM_Color_Index/default/2014-01-01/EPSG4326_31m/${z}/${y}/${x}.png
</ServerUrl>
</Service>
<DataWindow>
<UpperLeftX>-180.0</UpperLeftX>
<UpperLeftY>90</UpperLeftY>
<LowerRightX>396.0</LowerRightX>
<LowerRightY>-198</LowerRightY>
<TileLevel>11</TileLevel>
<TileCountX>2</TileCountX>
<TileCountY>1</TileCountY>
<YOrigin>top</YOrigin>
</DataWindow>
<Projection>EPSG:4326</Projection>
<BlockSizeX>512</BlockSizeX>
<BlockSizeY>512</BlockSizeY>
<BandsCount>4</BandsCount>
</GDAL_WMS>
I made two changes in order to make it work properly.
1. I think that the resolution is actually 31m which I found here
http://map1.vis.earthdata.nasa.gov/wmts-geo/1.0.0/WMTSCapabilities.xml
2. The TileLevel is 11, which I believes follows from the increased
resolution.
Anyway, the following command (adapted from one of the examples on the
page) works beautifully:
gdal_translate -outsize 1200 1000 -projwin -105 42 -93 32 my.xml out.tif
However, it produces four bands of a colored GeoTIFF, whereas I'd like
elevation values instead.
Is there some way to get elevation VALUES from this?
Normally, elevation values in the GDAL world come in a single band. Did I
overlook another Layer name that has elevation values? Or is there some
way to lookup elevations given the RGBA values?
Thank you very much,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150713/68c1e0a9/attachment.html>
