[gdal-dev] Wrongly identified SQLITE_BLOB as geomtry
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Oct 24 05:00:25 PDT 2016
It does smell like a bug. Could you repeat my test and take care to have the
additional BLOB field created after the geometry field? For me this
workaround seems to work and there is only one geometry left and "data"
field is reported as "binary" type.
FID Column = ogc_fid
Geometry Column = geometry
end: String (0.0)
start: String (0.0)
station_id: Integer (0.0)
timestep: Integer (0.0)
type: String (0.0)
data: Binary (0.0)
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Wrongly-identified-SQLITE-BLOB-as-geomtry-tp5292220p5292293.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
