[gdal-dev] splitting other_tags from .osm file
    Djordje Spasic
    issworld2000 at yahoo.com
    Sat Oct 29 14:21:00 PDT 2016
Thank you for the quick reply Even.
> You could as well putaddr:postcode as value in attribute=
This means that the name of the key (field) will be:"addr:postc", to accommodate those 10 maximal characters reserved for shapefile key (field) names?
Even do you mind if I ask you what is the difference betweenother_tags, and all_tags?There is an exaplanation in the osmconf.ini:
"all_tags" and"other_tags" are exclusive
But I do not understand it.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161029/748dfaf2/attachment-0003.html>
