[gdal-dev] port/md5 cvs_MD5*
Kurt Schwehr schwehr at gmail.com
Wed Dec 20 07:56:23 PST 2017
Dmitry,
Statements like this indicate a world of trouble:
> I'm not sure that Python produce the same hash than cvs_MD5*.
> Also I'm not sure what in future they will be the same.
If you remove the swig and python stuff, move the CPLMD5String to
cpl_md5.{cpp,h}, and follow Even's suggestions, I will be much happier with
the change.  A C++ test would be good too.  I'll be happy to do a quick fix
up of a few things that I see in the md5 code once it is to that point.  I
do think it is a good thing that there be md5 support in port along with
the existing sha{1,256} code.
I see what you are saying about the OGRGeometry::exportTo{json,kml,gml},
but that doesn't (to me) support your argument.  My personal opinion is
that GDAL would have been stronger if those had separate and not been a
part of OGRGeometry.
If there is a critical difference between CPLMD5String or a language and
use case where md5 support in that language from GDAL is really required,
you need to first document that issue.
On Wed, Dec 20, 2017 at 7:46 AM, Dmitry Baryshnikov <bishop.dev at gmail.com>
wrote:
> Just the note that CPLMD5String not only for Python, but any other API
> clients: C/C++, Java, Perl, etc.
> But, I agree, it can be easily removed.
> Best regards,
>     Dmitry
> 20.12.2017 18:35, Even Rouault пишет:
>> And why are you exposing this to python?  Python has md5 hashing
>>> already
>>> built in.
>> I do hope they return the same thing. MD5 is a standardized algorithm:
>> https://tools.ietf.org/html/rfc1321
>> I'm not sure we really need to expose it our CPL MD5 through Python.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171220/721fdbaf/attachment-0001.html>
