[gdal-dev] port/md5 cvs_MD5*
Ari Jolma
ari.jolma at gmail.com
Wed Dec 20 13:32:25 PST 2017
My comments on this:
1) The MD5 function seems to be needed only(?) for the WMS cache and
probably also WFS. To me that highlights the need for some integration
work regarding caching in GDAL. I also implemented yet another caching
code for the WCS (without MD5). Looking at my $HOME/.gdal I see also
gmlas_xsd_cache and srs_cache.
2) This discussion thread also highlights the need to go towards more
pull request style development at least for bigger changes.
Ari
Kurt Schwehr kirjoitti 21.12.2017 klo 02:56:
> Dmitry,
> Statements like this indicate a world of trouble:
> > I'm not sure that Python produce the same hash than cvs_MD5*.
> > Also I'm not sure what in future they will be the same.
> If you remove the swig and python stuff, move the CPLMD5String to
> cpl_md5.{cpp,h}, and follow Even's suggestions, I will be much happier
> with the change. A C++ test would be good too. I'll be happy to do a
> quick fix up of a few things that I see in the md5 code once it is to
> that point. I do think it is a good thing that there be md5 support
> in port along with the existing sha{1,256} code.
> I see what you are saying about
> the OGRGeometry::exportTo{json,kml,gml}, but that doesn't (to me)
> support your argument. My personal opinion is that GDAL would have
> been stronger if those had separate and not been a part of OGRGeometry.
> If there is a critical difference between CPLMD5String or a language
> and use case where md5 support in that language from GDAL is really
> required, you need to first document that issue.
> On Wed, Dec 20, 2017 at 7:46 AM, Dmitry Baryshnikov
> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
> Just the note that CPLMD5String not only for Python, but any other
> API clients: C/C++, Java, Perl, etc.
> But, I agree, it can be easily removed.
> Best regards,
> Dmitry
> 20.12.2017 18 <tel:20.12.2017%2018>:35, Even Rouault пишет:
> And why are you exposing this to python? Python has
> md5 hashing
> already
> built in.
> I do hope they return the same thing. MD5 is a standardized
> algorithm:
> https://tools.ietf.org/html/rfc1321
> <https://tools.ietf.org/html/rfc1321>
> I'm not sure we really need to expose it our CPL MD5 through
> Python.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171221/f4e8fee2/attachment.html>
