[gdal-dev] error reading AIG blocks
Gregory, Matthew matt.gregory at oregonstate.edu
Thu May 11 16:29:15 PDT 2017
Hi all,
I think this is a bug, but wanted to make sure I wasn't doing something stupid before I posted it as such.
At r32878 (git 1eb605a), Even added new logic for dealing with raw 32-bit AIG blocks.  I've got an AIG raster that has a few blocks where valid data is getting set to the min Int32 value (-2147483648) when doing a gdal_translate to GeoTiff.
  gdal_translate -of GTiff ai_bug ai_bug.tif
Note the "old" way of getting these values was providing the correct values in this case:
  panData[i] = pabyCur[0] * 256 * 256 * 256
      + pabyCur[1] * 256 * 256
      + pabyCur[2] * 256
      + pabyCur[3] + nMin;
Note that this is only affecting selected blocks within the raster.  Other blocks seem to be just fine.
Test raster posted here:
  ftp://ftp.fsl.orst.edu/pub/gregorym/gdal/ai_bug.7z (1MB)
>From my testing, <= 2.0 is OK, >= 2.1 is affected.  Tested on Windows 10 64-bit.
thanks, matt
