[gdal-dev] vsicurl configuration design decisions
Even Rouault even.rouault at spatialys.com
Tue Oct 10 03:02:58 PDT 2017
Hi Sean,
> It's written in
> http://gdal.org/gdal_virtual_file_systems.html#gdal_virtual_file_systems_vsi
> curl
> > Starting with GDAL 2.3, options can be passed in the filename with the
> following syntax: /vsicurl/option1=val1[,optionN=valN]*,url=http://...
> I'd like to discuss the design decisions that are being made here before
> this gets out into the world.
> I'm uncomfortable with the way configuration is spread between environment
> variables, config options that surface in the API,
Just a precision: GDAL only reads configuration options with CPLGetConfigOption(key).
Those can be implictly set through environment variables of the same name or with
CPLSetConfigOption(key, value).
> and also in identifiers.
> I don't think it's a great idea to that expand the amount of configuration
> in dataset identifiers. It's redundant, the syntax is complicated,
Frank answered on the main motivations.
> and it
> dilutes the network effects of reusing identifiers in our applications.
Didn't understand what you meant with the above sentence.
> Are there specific advantages to this
>   ogrinfo -so /vsicurl/max_retry=10,url=https://example.com/poly.shp
> that we can't also have with a curl-style
>   ogrinfo -so --max-retry=10 /vsicurl/https://example.com/poly.shp
> or, better yet, in my opinion
>   ogrinfo -so --max-retry=10 https://example.com/poly.shp
> on the command line?
One issue with you proposal is that it would require ogrinfo (or any utility) to go from the
highest level abstraction layers of GDAL to the lowest ones.
When ogrinfo is provided
"/vsicurl/max_retry=10,url=https://example.com/poly.shp",
this is just a string used as a dataset name
It happily feeds it into GDALOpenEx(), which in turns proposes it sequentially to all drivers
The shapefile driver tries this string with VSIFOpenL(), which in turns iterates over all virtual
file systems. The /vsicurl/ VFS happens to recognize it, manages to open the file. The
shapefile driver can read the few first bytes from it and recognizes that it is a header of a
shapefile, etc..
So in the current design neither the utility, nor GDALOpenEx(), or the drivers themselves
really make a sense of that string. This is quite a strength at the architectural level. This also
enables to pass such a string in a VRT file for example.
Regarding the direct use of http:// https:// , I also find it is a bit unfortunate that we can't use
them directly and vsicurl machinery would be implictly used. It turns that historically we have
the HTTP driver that triggers on such dataset name (ingesting the whole file into /vsimem/,
and proposing it in turn to other drivers). There's also a few other drivers (DODS, etc..) that
trigger on such names.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171010/e11c141e/attachment.html>
