[gdal-dev] pthread_setspecific() failed error
Even Rouault
even.rouault at spatialys.com
Mon Aug 13 23:01:30 PDT 2018
On lundi 13 août 2018 16:44:24 CEST Colleen Rooney wrote:
> Hello,
> I am attempting to build gdal version 2.3.1 from source. I am using gcc
> 7.2.0, and enabling support for proj4 version 5.1.0, grass version 7.4.0,
> xerces-C version 3.1, hdf5 version 1.10.2, netcdf version 4.4.1.1, python
> version 3.6.4, and perl version 5.16.3. Configure, make, and make install
> all complete. However when the resulting executables are run I get an error
> such as the following:
> $ ./gdalinfo --version
> GDAL 2.3.1, released 2018/06/22
> CPLGetTLSList(): pthread_setspecific() failed!
> I have hit a wall trying to figure out what is causing this error. Any help
> would be appreciated, let me know any additional information you require!
This is a weird one. Which operating system is this ?
Can you retry building GDAL without any of the dependency at all and see if
that makes a difference ?
Even
http://www.spatialys.com
