[gdal-dev] Complex valued NoData
    Even Rouault
    even.rouault at spatialys.com
    Wed Jul 25 01:29:48 PDT 2018
Piyush,
>     We are working on use cases where we have to perform operations similar
> to gdal_translate / gdalwarp on complex valued datasets.
> The last discussion that I could on this topic in the mailing archives is
> from 2010:
> https://lists.osgeo.org/pipermail/gdal-dev/2010-September/025906.html
> I’m willing to put in some effort to update the algorithms to handle nodata
> values for complex valued datasets properly (which it currently appears to
> ignore). Any pointers on where to start looking or focus on would help?
gcore/overview.cpp
alg/gdalwarpkernel.cpp
> We would like to avoid using pixel functions and manipulating the real/imag
> parts independently and then putting them back together.
> There are also different options for interpreting nodata. I believe we are
> limited to real values for this metadata field and adding new fields /
> changing the type could be pretty disruptive.
>   1.  Compare real value only (seems easiest to implement)
>   2.  Compare that both real and imaginary values are set to no data
> (probably better way of checking?)
> If one were to implement nodata support for complex-valued datasets, which
> implementation would be preferred.
Probably that comparing the real value only would be the best way to go
Looking quickly, I see we have some inconsistency of behaviour. For example
GDALRasterBand::GetHistogram() takes the norm of the value before comparing to
nodata, whereas ComputeStatistics() only compares (and takes into account) the
real value.
Even
http://www.spatialys.com
