[gdal-dev] gdalwarp together with proj5 pipelines
Even Rouault
even.rouault at spatialys.com
Tue Sep 18 12:51:23 PDT 2018
On mardi 18 septembre 2018 21:27:03 CEST Markus Metz wrote:
> On Tue, Sep 18, 2018 at 4:25 PM Dalia Prizginiene <dalia at lmi.is> wrote:
> > Hello,
> > Thank you for your reply, but that to be sure: does it mean that gdalwarp
> at the moment does not allow also horizontal grid shift like
> "+proj=hgridshift +grids=ISN93_16.gsb" or "+proj=latlong
> +nadgrid=xxxx.gsb" ?
You cannot use proj=hgridshift, but you can use
"+proj=latlong +ellps=... +nadgrids=xxxx.gsb"
Note: this is nadgrids with a final s
http://www.spatialys.com
