[gdal-dev] PHP_OGR
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Feb 26 10:17:28 PST 2019
Hi Edward,
For many years (decade?) I distributed the PHP/OGR extension for Windows
users, in MS4W. Since the extension was unmaintained I had removed it,
but, hearing that you have revived it, I will re-add it back into MS4W
(version 4, which includes PHP 7.2.x). If you wish to follow along with
this, here is the ticket that I will use to track adding it:
https://ms4w.com/trac/ticket/190 I imagine I may have some 'fun' trying
to adapt the old makefile.vc for PHP7 ;)
Thanks!
-jeff
On 2019-02-26 1:14 PM, Nash, Edward wrote:
> Hi devs,
> If there’s anyone out there using or supporting PHP then you may be
> interested that I recently pushed an update to PHP_OGR (yes, forked from
> the original from DM Solutions exhumed from CVS!) to GitHub [1] which
> adds support for PHP7, a bunch of functions for coordinate systems (OSR
> API) and some reworked and extended PHPUnit tests.
> It’s not necessarily pretty or modern, and doesn’t cover everything in
> the current API, but it is still very functional and allows access to at
> least some of the main OGR functions directly from PHP.
> If there’s anyone out there who would like to take it for a spin on
> different systems (tested so far only on Debian Jessie and Stretch),
> then I’d be very happy to accept any resulting pull requests.
> Cheers,
> Edward
> [1] https://github.com/dvzgeo/php_ogr
> Edward Nash
> Sachgebiet Geoinformation
> E-Mail E.Nash at dvz-mv.de <mailto:E.Nash at dvz-mv.de>
> Telefon: +49 385 4800 527
> Telefax: +49 385 4800 98 527
> Mobilfunk: +49 170 454 7434
> Internet: www.dvz-mv.de <http://www.dvz-mv.de/>
> _____________________________________
> DVZ Datenverarbeitungszentrum
> Mecklenburg-Vorpommern GmbH
> Lübecker Str. 283 - 19059 Schwerin
> Sitz der Gesellschaft: Schwerin | Eintrag im Handelsregister: HRB 187/
> Amtsgericht Schwerin
> Geschäftsführer: Hubert Ludwig | Aufsichtsratsvorsitzender:
> Staatssekretärin Ina-Maria Ulbrich
> Allgemeine Datenschutzinformation: Der telefonische, schriftliche oder
> elektronische Kontakt ist ggf. mit der Speicherung und Verarbeitung der
> von Ihnen mitgeteilten persönlichen Daten verbunden. Sollte die DVZ M-V
> GmbH Daten von Ihnen erhalten, dann werden diese zweckbezogen erhoben
> und verarbeitet. Eine Datenverarbeitung zu anderen Zwecken kommt nur
> dann in Betracht, wenn die insoweit erforderlichen rechtlichen Vorgaben
> gemäß Art. 6 Abs. 4 DSGVO vorliegen. Die DVZ M-V GmbH beachtet etwaige
> Informationspflichten nach Art. 13 Abs. 3 DSGVO und Art. 14 Abs. 4 DSGVO
> sowie das Widerspruchsrecht nach Art. 21 DSGVO. Weitere Informationen
> erhalten Sie auf https://www.dvz-mv.de/Datenschutz/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
