[gdal-dev] PHP_OGR
Nash, Edward E.Nash at dvz-mv.de
Tue Feb 26 22:47:36 PST 2019
Hi Jeff,
that's great. I pulled in a couple of commits from Alexander Gabriel that had to do with building on Windows, but I've no idea whether he actually managed to do that successfully - and in any case that would still have been for PHP 5. For PHP7 on Linux I actually didn't need to make any changes in the makefile at all.
Unfortunately I can't really offer much help on the Windows front - but since I do occasionally use ms4w then I wish you success!
Regards,
Edward
-----Ursprüngliche Nachricht-----
Von: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] Im Auftrag von Jeff McKenna
Gesendet: Dienstag, 26. Februar 2019 19:17
An: gdal-dev at lists.osgeo.org
Betreff: Re: [gdal-dev] PHP_OGR
Hi Edward,
For many years (decade?) I distributed the PHP/OGR extension for Windows users, in MS4W.  Since the extension was unmaintained I had removed it, but, hearing that you have revived it, I will re-add it back into MS4W (version 4, which includes PHP 7.2.x).  If you wish to follow along with this, here is the ticket that I will use to track adding it:
https://ms4w.com/trac/ticket/190  I imagine I may have some 'fun' trying to adapt the old makefile.vc for PHP7 ;)
Thanks!
-jeff
On 2019-02-26 1:14 PM, Nash, Edward wrote:
> Hi devs,
> If there’s anyone out there using or supporting PHP then you may be
> interested that I recently pushed an update to PHP_OGR (yes, forked
> from the original from DM Solutions exhumed from CVS!) to GitHub [1]
> which adds support for PHP7, a bunch of functions for coordinate
> systems (OSR
> API) and some reworked and extended PHPUnit tests.
> It’s not necessarily pretty or modern, and doesn’t cover everything in
> the current API, but it is still very functional and allows access to
> at least some of the main OGR functions directly from PHP.
> If there’s anyone out there who would like to take it for a spin on
> different systems (tested so far only on Debian Jessie and Stretch),
> then I’d be very happy to accept any resulting pull requests.
> Cheers,
> Edward
> [1] https://github.com/dvzgeo/php_ogr
> Edward Nash
> Sachgebiet Geoinformation
> E-Mail E.Nash at dvz-mv.de <mailto:E.Nash at dvz-mv.de>
> Telefon: +49 385 4800 527
> Telefax: +49 385 4800 98 527
> Mobilfunk: +49 170 454 7434
> Internet: www.dvz-mv.de <http://www.dvz-mv.de/>
> _____________________________________
> DVZ Datenverarbeitungszentrum
> Mecklenburg-Vorpommern GmbH
> Lübecker Str. 283 - 19059 Schwerin
> Sitz der Gesellschaft: Schwerin | Eintrag im Handelsregister: HRB 187/
> Amtsgericht Schwerin
> Geschäftsführer:  Hubert Ludwig | Aufsichtsratsvorsitzender:
> Staatssekretärin Ina-Maria Ulbrich
> Allgemeine Datenschutzinformation: Der telefonische, schriftliche oder
> elektronische Kontakt ist ggf. mit der Speicherung und Verarbeitung
> der von Ihnen mitgeteilten persönlichen Daten verbunden. Sollte die
> DVZ M-V GmbH Daten von Ihnen erhalten, dann werden diese zweckbezogen
> erhoben und verarbeitet. Eine Datenverarbeitung zu anderen Zwecken
> kommt nur dann in Betracht, wenn die insoweit erforderlichen
> rechtlichen Vorgaben gemäß Art. 6 Abs. 4 DSGVO vorliegen. Die DVZ M-V
> GmbH beachtet etwaige Informationspflichten nach Art. 13 Abs. 3 DSGVO
> und Art. 14 Abs. 4 DSGVO sowie das Widerspruchsrecht nach Art. 21
> DSGVO. Weitere Informationen erhalten Sie auf
> https://www.dvz-mv.de/Datenschutz/
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Jeff McKenna
MapServer Consulting and Training Services https://gatewaygeomatics.com/ _______________________________________________
