[gdal-dev] Vagrant build environment
Craig de Stigter craig.destigter at koordinates.com
Mon Jun 24 00:16:46 PDT 2019
Hi folks
I sat down to finish off a pull request I started months ago, and realised
that GDAL's vagrant build no longer works. It fails quite early in
provisioning.
I think this is probably because Ubuntu 14.04 is no longer in upstream
support, and the ubuntugis PPA has stopped supplying packages for it:
>     default: Unable to locate package postgresql-9.3-postgis-2.2
>     default: Unable to locate package libopenjp2-7-dev
>     default: Unable to locate package libopenjpip7
>     default: Unable to locate package libopenjp3d7
Is there a newer recommended way to easily get a dev build of GDAL running,
with a reasonably complete set of drivers? An updated vagrantfile for
Ubuntu 18.04 would be pretty ideal...
Regards,
Craig
Developer
Koordinates
+64 21 256 9488 <+64%2021%20256%209488> / koordinates.com / @koordinates
<https://twitter.com/koordinates>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190624/ac054d4b/attachment.html>
