[gdal-dev] Add padding to an image
Jeremy Palmer
palmerjnz at gmail.com
Fri Nov 8 01:09:31 PST 2019
Sure. no problem. I posted the question here
https://gis.stackexchange.com/questions/341188/add-padding-when-resizing-an-image
Thanks
Jeremy
On Fri, Nov 8, 2019 at 7:23 PM jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Have you considered to ask this question from gis.stackexcange? As a
> platform it suits better for a question like this that has many alternative
> and perhaps opinion based answers. It allows also an easier way for you to
> improve your question that in its current state would probably be closed in
> gis.stackexchange as "too broad" or "unclear what you're asking", or
> perhaps
> "primarily opinion-based".
> Could you explain what you mean with padding, and if you would rather use
> some GDAL program or for example Python?
> -Jukka Rahkonen-
> Jeremy Palmer-3 wrote
> > Hi All,
> > What the best way to pad an output RGBA image with gdal tools?
> > Thanks in advance.
> > Cheers
> > Jeremy
> > gdal-dev mailing list
> > gdal-dev at .osgeo
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191108/5f2534ed/attachment-0001.html>
