[gdal-dev] Compile problems gdal3.0.2 against proj6
Mateusz Loskot
mateusz at loskot.net
Tue Nov 19 05:01:57 PST 2019
On Tue, 19 Nov 2019 at 13:41, Andreas Neumann <a.neumann at carto.net> wrote:
> I am trying to compile gdal3.0.2 against proj6 - but have problems.
> Proj6 compile worked fine and I installed in /usr/local
> The configure command for gdal is:
> ./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes --with-spatialite=yes
> /bin/bash /home/bjsvwneu/dev/gdal-3.0.2/libtool --mode=link --silent g++ gdalinfo_bin.lo /home/bjsvwneu/dev/gdal-3.0.2/libgdal.la -o gdalinfo
> /home/bjsvwneu/dev/gdal-3.0.2/.libs/libgdal.so: undefined reference to `proj_alter_name'
Try
https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050184.html
https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050189.html
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
