[gdal-dev] Compile problems gdal3.0.2 against proj6
Andreas Neumann a.neumann at carto.net
Tue Nov 19 05:15:16 PST 2019
Thanks for your reply.
Here is the output of configure:
user at machine:~/dev/gdal-3.0.2$ ./configure --with-python=python3
--with-proj=/usr/local --with-pg=yes --with-spatialite=yes | grep proj
/bin/bash: ./config.rpath: No such file or directory
checking for PROJ >= 6 library... checking for proj_create_from_wkt in
-lproj... yes
configure: proj.h found
config.status: WARNING:  'GDALmake.opt.in' seems to ignore the
--datarootdir setting
And here the output of ldd:
user at machine:~/dev/gdal-3.0.2$ ldd .libs/libgdal.so | grep proj
       libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
(0x00007f72525a5000)
So this seems like it links to the old version of proj. Why is using
this one if I specified "--with-proj=/usr/local" ?
The env var LD_LIBRARY_PATH is not set on my machine.
Maybe setting one and set /usr/local as the preferred path would solve
my problem. I'll try ...
Thanks,
Andreas
On 2019-11-19 14:01, Mateusz Loskot wrote:
> On Tue, 19 Nov 2019 at 13:41, Andreas Neumann <a.neumann at carto.net> wrote:
>> I am trying to compile gdal3.0.2 against proj6 - but have problems.
>> Proj6 compile worked fine and I installed in /usr/local
>> The configure command for gdal is:
>> ./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes --with-spatialite=yes
>> /bin/bash /home/bjsvwneu/dev/gdal-3.0.2/libtool --mode=link --silent g++  gdalinfo_bin.lo  /home/bjsvwneu/dev/gdal-3.0.2/libgdal.la  -o gdalinfo
>> /home/bjsvwneu/dev/gdal-3.0.2/.libs/libgdal.so: undefined reference to `proj_alter_name'
> Try
> https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050184.html
> https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050189.html
> Best regards,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191119/64ce5061/attachment.html>
