[gdal-dev] Compile problems gdal3.0.2 against proj6
Andreas Neumann a.neumann at carto.net
Tue Nov 19 05:26:40 PST 2019
Hm - setting the LD_LIBRARY_PATH variable also didn't help. ldd still
says that it links to the old proj.
Still the same error message.
I did a "make clean" to make sure no old stuff is around from previous
attempts. Do I really have to purge the old proj version? Then several
other of the packages on my machine would fail to work ...
Andreas
On 2019-11-19 14:15, Andreas Neumann wrote:
> Hi,
> Thanks for your reply.
> Here is the output of configure:
> user at machine:~/dev/gdal-3.0.2$ ./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes --with-spatialite=yes | grep proj
> /bin/bash: ./config.rpath: No such file or directory
> checking for PROJ >= 6 library... checking for proj_create_from_wkt in -lproj... yes
> configure: proj.h found
> config.status: WARNING:  'GDALmake.opt.in' seems to ignore the --datarootdir setting
> And here the output of ldd:
> user at machine:~/dev/gdal-3.0.2$ ldd .libs/libgdal.so | grep proj
> libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12 (0x00007f72525a5000)
> So this seems like it links to the old version of proj. Why is using this one if I specified "--with-proj=/usr/local" ?
> The env var LD_LIBRARY_PATH is not set on my machine.
> Maybe setting one and set /usr/local as the preferred path would solve my problem. I'll try ...
> Thanks,
> Andreas
> On 2019-11-19 14:01, Mateusz Loskot wrote:
> On Tue, 19 Nov 2019 at 13:41, Andreas Neumann <a.neumann at carto.net> wrote: I am trying to compile gdal3.0.2 against proj6 - but have problems.
> Proj6 compile worked fine and I installed in /usr/local
> The configure command for gdal is:
> /bin/bash /home/bjsvwneu/dev/gdal-3.0.2/libtool --mode=link --silent g++  gdalinfo_bin.lo  /home/bjsvwneu/dev/gdal-3.0.2/libgdal.la  -o gdalinfo
> /home/bjsvwneu/dev/gdal-3.0.2/.libs/libgdal.so: undefined reference to `proj_alter_name'
> Try
> https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050184.html
> https://lists.osgeo.org/pipermail/gdal-dev/2019-May/050189.html
> Best regards,
gdal-dev mailing list
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191119/378d9ceb/attachment.html>
