[gdal-dev] GDAL 3 + PROJ 6 performance issue in CENTOS
Vincent Sarago vincent.sarago at gmail.com
Thu Nov 28 12:37:51 PST 2019
Again Even you are my hero,
$ sqlite3 --version
3.7.17 2013-05-20 00:56:22 118a3b35693b134d56ebd780123b7fd6f1497668
Will try to update and see how it goes,
Thanks a lot
> Le 28 nov. 2019 à 15:34, Even Rouault <even.rouault at spatialys.com> a écrit :
>> The full discovery can be seen in
>> https://github.com/RemotePixel/amazonlinux/issues/10
>> <https://github.com/RemotePixel/amazonlinux/issues/10> and
>> https://github.com/RemotePixel/amazonlinux/issues/16
>> <https://github.com/RemotePixel/amazonlinux/issues/16>.
>> The dockerfile can be found here
>> https://github.com/RemotePixel/amazonlinux/blob/master/base/gdal3.0/Dockerf
>> ile
>> <https://github.com/RemotePixel/amazonlinux/blob/master/base/gdal3.0/Docker
>> file>
>> The logs (PROJ or GDAL) don’t tell anything, they are almost similar. The
>> only notable difference is : ```
>> # CENTOS
>> GDAL: GDALDriver::Create(GTiff,out.tif,256,256,1,UInt16,(nil))
> Vincent, now I see CentOS, I'm pretty sure now that you hit:
> https://lists.osgeo.org/pipermail/proj/2019-November/008984.html
> Basically we discovered that while PROJ 6 compiled and worked against CentOS 7
> system sqlite, the query optimized of this sqlite version did a bad job that
> could result in dramatic performance issues as you found. So the fix is to run
> against a not too old sqlite. We have set the minimum to sqlite 3.11.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
