[gdal-dev] Current state of Winkel Tripel projection support
domlysz
domlysz at gmail.com
Tue Jun 2 06:02:29 PDT 2020
Hi Even,
Thanks for the answer, my double mistakes the srs I wanted to talk about is
the number 54042 and you're right this is an ESRI code, I can't believe I
don't see it !
The error messages happen when trying to reproject to EPSG:54042 which does
ot exists at all, with GDAL 2.3. So I resolved the issue by updating GDAL
and simply use the syntax -t_srs "+proj=wintri"
I'm very sorry to have bored the list with my mistakes, and thanks again for
your help.
Dominique
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
