[gdal-dev] Binaries of GDAL JNI
Even Rouault even.rouault at spatialys.com
Tue May 26 06:06:19 PDT 2020
On mardi 26 mai 2020 14:39:02 CEST Dirk Stenger wrote:
> Hi all,
> We are using GDAL in Java applications via JNI.
> For that, we install GDAL JNI on Ubuntu or Debian by using package
> "libgdal-java".
> However, the number of available GDAL JNI versions is limited to one.
> Thus, it is not possible to install an old GDAL + GDAL JNI version (e.g.
> 2.4) on the current release of Ubuntu.
> We also had problems to install GDAL JNI on other Linux distributions
> not providing package "libgdal-java".
> Is there any place where we can download binaries of current and older
> versions of GDAL JNI like it is possible for GDAL itself
> (https://gdal.org/download.html)?
You'll have to build it yourself from the corresponding source archive of the GDAL version
you're interested in.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200526/7ade0803/attachment.html>
