[gdal-dev] Call for discussion on RFC77 Drop Python 2 support
Momtchil Momtchev momtchil at momtchev.com
Wed Nov 18 05:38:30 PST 2020
     Hello,
It seems that you have already decided, but just for your information,
there is this page:
https://python3statement.org/
Maybe you can add GDAL too
2020 will be the year that most major packages will start dropping
Python 2 support. 2018 was the year that most major distributions
switched their default interpreters to Python 3.
On 16/11/2020 16:13, Even Rouault wrote:
> Sean,
>> It makes sense to me. I'm not aware of GDAL needing any features of Python
>> 3.7, so 3.6 sounds good.
>> Since the project hasn't dropped support for a Python version in a long
>> time, maybe there should be a plan to warn in code
> Idan has a pull request in https://github.com/OSGeo/gdal/pull/3165 adding a
> deprecation warning if running a Python version that is known to be
> unsupported in the the next GDAL version. We should merge this in the 3.2
> branch too for 3.2.1
>> and make announcements on OSGeo lists?
> Would indeed makes sense to announce that in the release notes of 3.2.1 too
> Even
Momtchil Momtchev <momtchil at momtchev.com>
