[gdal-dev] Serve COG images - GEE & Google Cloud Storage
    Travis Kirstine
    traviskirstine at gmail.com
    Fri Sep  4 05:34:55 PDT 2020
There is a good article here on how to do this using MapServer and S3, this
may work for Google as well
https://github.com/mapserver/mapserver/wiki/Render-images-straight-out-of-S3-with-the-vsicurl-driver
You can configure MapServer as a WMS server and add the layers to Open
Layers or take the extra step and configure MapCache to generate a tiled
output and caching using your WMS as source
On Fri, 4 Sep 2020 at 03:01, Even Rouault <even.rouault at spatialys.com>
wrote:
> Arun,
> Not sure this completely answer your question, but GDAL has gained a
> Google Cloud Storage virtual file system handler similar
> to the AWS S3 one since the post you mention.
> See
> https://gdal.org/user/virtual_file_systems.html#vsigs-google-cloud-storage-files
> Even
> > Hi
> > In this article, I came across about servicing rasters on AWS S3:
> https://www.azavea.com/blog/2019/04/23/using-cloud-optimized-geotiffs-cogs/
> > , https://lists.osgeo.org/pipermail/gdal-dev/2015-October/042975.html
> > I am trying to see if something similar exists for Google? I'm exporting
> > COG from Google Earth Engine (GEE) to a Google Cloud Storage bucket in
> the
> > hopes to access and serve it with other layers using GeoServer or create
> > tile map services. I've many dates and many products (true color, false
> > color, ndvi) for many sites. So I'm not sure what's the best way to serve
> > them. I tried researching online, asking in StackExchange, GeoServer and
> > GEE forums and reaching out to a few people, but I couldn't get specific
> > info... Most info is on AWS and S3...
> > My requirement is to somehow get the images of "GEE to bucket" exported
> > images into Openlayers (web mapping) and JavaScript (frontend). GEE can
> > export to my Drive or a GCP bucket. So serving from GEE to GCP to S3
> means
> > some download, unzip, zip and upload - so more time consuming and manual
> > steps. In my experience, AWS was costly (as my EC2 runs all the time)
> than
> > a VPS server...
> > I'll appreciate your help. Thank you!
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200904/85da063a/attachment.html>
