[gdal-dev] Test Failures
Andrew Bell
andrew.bell.ia at gmail.com
Wed Apr 28 05:20:47 PDT 2021
Here is the output tif file along with the command and its terminal output.
On Tue, Apr 27, 2021 at 3:02 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 27/04/2021 à 20:49, Andrew Bell a écrit :
> On Tue, Apr 27, 2021 at 2:27 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Andrew,
>> This could be due to the PROJ version, but as I'm running with 8.0 too
>> (and one of the CI config runs PROJ master), I suspect you just need to
>> install the "conus" grid for NAD27 to WGS84 transformations into
>> {proj_prefix}/share/proj . Unpack
>> http://download.osgeo.org/proj/proj-datumgrid-1.8.tar.gz
> I have PROJ_NETWORK set to ON. I was under the impression that this would
> cause PROJ to find whatever grids shift files it needed at runtime. Is
> there more configuration that's necessary to get this to happen or do I
> misunderstand the PROJ_NETWORK setting?
> That should be fine. Actually I was wrong. This test case doesn't involve
> any datum shift / grids as it is EPSG:4326 to EPSG:3857 reprojection.
> That might then just be a subtle different rounding issue in computations
> in GDAL and/or PROJ, or more likely, due to using a different JPEG library
> as this test case involves JPEG compression. If that was the case, you
> might add your checksums as an alternative expected output. We do that in a
> number of places.
> Looking a few lines before the failure, I actually see that the CI got
> that issue and we worked around it with:
> if sys.platform == 'darwin' and gdal.GetConfigOption('TRAVIS', None)
> is not None:
> assert got_cs != [0, 0, 0]
> else:
> Could you run
> gdal_translate ../autotest/gdrivers/data/small_world.tif out.tif -of COG
> co TILING_SCHEME=GoogleMapsCompatible -co COMPRESS=JPEG
> and attach the resulting file ?
> Thanks,
> Andrew Bell
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210428/a75f6cb9/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210428/a75f6cb9/attachment-0001.bin>
