[gdal-dev] Test Failures
Even Rouault
even.rouault at spatialys.com
Wed Apr 28 05:35:00 PDT 2021
Andew,
visually the difference between your image and the one generated on my
PC are almost indistinguishable (no spatial shift at least). Please
submit a PR adding your checksums as alternate accepted ones. You may
just remove the "if sys.platform == 'darwin'" case. Hopefully adding
your checksums should fix the OSX CI too
Even
Le 28/04/2021 à 14:20, Andrew Bell a écrit :
> Here is the output tif file along with the command and its terminal
> output.
> On Tue, Apr 27, 2021 at 3:02 PM Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
> Le 27/04/2021 à 20:49, Andrew Bell a écrit :
>> On Tue, Apr 27, 2021 at 2:27 PM Even Rouault
>> wrote:
>> Andrew,
>> This could be due to the PROJ version, but as I'm running
>> with 8.0 too (and one of the CI config runs PROJ master), I
>> suspect you just need to install the "conus" grid for NAD27
>> to WGS84 transformations into {proj_prefix}/share/proj .
>> Unpack
>> http://download.osgeo.org/proj/proj-datumgrid-1.8.tar.gz
>> <http://download.osgeo.org/proj/proj-datumgrid-1.8.tar.gz>
>> I have PROJ_NETWORK set to ON. I was under the impression that
>> this would cause PROJ to find whatever grids shift files it
>> needed at runtime. Is there more configuration that's necessary
>> to get this to happen or do I misunderstand the PROJ_NETWORK setting?
> That should be fine. Actually I was wrong. This test case doesn't
> involve any datum shift / grids as it is EPSG:4326 to EPSG:3857
> reprojection.
> That might then just be a subtle different rounding issue in
> computations in GDAL and/or PROJ, or more likely, due to using a
> different JPEG library as this test case involves JPEG
> compression. If that was the case, you might add your checksums as
> an alternative expected output. We do that in a number of places.
> Looking a few lines before the failure, I actually see that the CI
> got that issue and we worked around it with:
> if sys.platform == 'darwin' and gdal.GetConfigOption('TRAVIS',
> None) is not None:
> assert got_cs != [0, 0, 0]
> else:
> Could you run
> gdal_translate ../autotest/gdrivers/data/small_world.tif out.tif
> -of COG co TILING_SCHEME=GoogleMapsCompatible -co COMPRESS=JPEG
> and attach the resulting file ?
>> Thanks,
>> Andrew Bell
>> andrew.bell.ia at gmail.com <mailto:andrew.bell.ia at gmail.com>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210428/ba0ce9a2/attachment.html>
