[gdal-dev] Test Failures
Andrew Bell andrew.bell.ia at gmail.com
Wed Apr 28 06:06:55 PDT 2021
Even,
Do you have any idea why the differences exist? Is it worth investigating?
On Wed, Apr 28, 2021 at 8:35 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Andew,
> visually the difference between your image and the one generated on my PC
> are almost indistinguishable (no spatial shift at least). Please submit a
> PR adding your checksums as alternate accepted ones. You may just remove
> the "if sys.platform == 'darwin'" case. Hopefully adding your checksums
> should fix the OSX CI too
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210428/4a1afad7/attachment.html>
