[gdal-dev] unicode support in GDAL
Claudiu Cochior
Claudiu.Cochior at bentley.com
Thu Aug 12 08:54:07 PDT 2021
Hello everybody,
I have a question related to Unicode strings in GDAL
We are using GDAL 3.0.4 and at some point we would like to write to shapefile a string that contains Russian characters. To give you some context, we are in C++, we created a OGRFeature and we want to set a field to the string that contains the Russian characters. My machine is in English and the language for non-unicode programs is set to English. I didn't find in the GDAL doc a definitive answer if GDAL support Unicode strings for filed values. As a test I converted the System::String to UTF-8 but the shape file displays only ? for the characters. If I change the language for non-unicode programs to Russian then I can safely extract the ANSI string and give it to the SetField method and the result is OK.
So, does GDAL supports unicede field string values somehow?
Thanks,
Claudiu
This email, including any attachments, may contain confidential and/or proprietary information intended only for the use of the recipient. If you are not the intended recipient, any distribution, copying, or use of this email or its attachments is prohibited. If you received this email in error, please reply to the sender immediately and delete this message and any copies.
Bentley Systems has taken all reasonable steps to ensure that this communication is free from viruses, data corruption, and unauthorized alteration. Bentley Systems does not accept liability for any damages that may be incurred as a result of this or any communication by email
[https://cdn2.webdamdb.com/310th_sm_UnR3pO7k0ir0.jpg?1616176329]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210812/156f0016/attachment.html>
