[gdal-dev] gdal installation error on MacOS (libpoppler.91.dylib)
    Paul Harwood
    runette at gmail.com
    Thu Dec  9 04:57:55 PST 2021
I think you would only have conflicts if you tried to use venv and conda in
the same environment/project because you would then end up trying to
use two different Python instances for one project and that will not work
:). You can use them separately on the same machine on a project by project
basis and conda and pip do live together.
On Thu, 9 Dec 2021 at 12:53, Idan Miara <idan at miara.com> wrote:
> Thanks for your help!
> I realised that since I use pyenv virtualenv then I might have conflicts
> if I also use conda.
> I ended up uninstalling conda and installing gdal with homebrew and pip.
> I will add some notes in the docs for how to avoid the pitfalls I
> encountered.
> On Tue, 7 Dec 2021 at 13:33, Daniel Scheffler <
> daniel.scheffler at gfz-potsdam.de> wrote:
>> If you installed into the base environment, you should rollback it to the
>> last clean revision. Use *conda list --revisions* to see which revision
>> number you need to use. Then use *conda install --revision N* (where N
>> is the revision number).
>> You should also make sure that your conda package resolver is up-to-date
>> before creating a new environment for gdal.  Otherwise, it might happen
>> that conda installs an old gdal version. To update it, run *conda update
>> conda* or *conda update --all* in your base environment. Note hat you
>> may have to add *-c conda-forge* to avoid mixing up packages coming from
>> the *main *channel with those from the *conda-forge* channel.
>> Am 07.12.2021 um 12:15 schrieb Paul Harwood:
>> Results like that are usually caused because there is something already
>> in the conda environment that is causing a conflict and I notice that it is
>> installing into  /Users/idan.miara/opt/miniconda3 which would usually
>> mean you have installed into the "base" conda environment - which is not
>> usually the best idea.
>> If you try ...
>> conda create --name gdaltest
>> conda activate gdaltest
>> conda install -c conda-forge gdal
>> {noteing that the name "gdaltest" in the first and second lines could be
>> any name for a conda environment that is not already in use}
>> ... I am reasonably sure it will work.
>> Then you just need to use the "gdaltest" environment when you want to use
>> conda.
>> On Tue, 7 Dec 2021 at 09:03, Idan Miara <idan at miara.com> wrote:
>>> Hi all,
>>> I'm trying to install gdal on MacOS Big Sur via conda.
>>> For some reason it installs v3.0.2, even though v3.4.0 is available.
>>> Also it doesn't run, and gives the following error:
>>> ~ gdalinfo --version
>>> dyld: Library not loaded: @rpath/libpoppler.91.dylib
>>> Thanks!
>>> logs are below.
>>> Kind regards,
>>> Idan
>>> Collecting package metadata (current_repodata.json): done
>>> Solving environment: done
>>> ## Package Plan ##
>>>   environment location: /Users/idan.miara/opt/miniconda3
>>>   added / updated specs:
>>>     - gdal
>>> The following packages will be downloaded:
>>>     package                    |            build
>>>     boost-cpp-1.72.0           |       hdf9ef73_0        19.1 MB
>>>  conda-forge
>>>     bzip2-1.0.8                |       h0d85af4_4         155 KB
>>>  conda-forge
>>>     c-ares-1.18.1              |       h0d85af4_0         100 KB
>>>  conda-forge
>>>     ca-certificates-2021.10.8  |       h033912b_0         139 KB
>>>  conda-forge
>>>     cairo-1.16.0               |    hec6a9b0_1003         1.3 MB
>>>  conda-forge
>>>     certifi-2021.10.8          |   py39h6e9494a_1         145 KB
>>>  conda-forge
>>>     cfitsio-3.470              |       h01dc385_7         1.3 MB
>>>  conda-forge
>>>     conda-4.11.0               |   py39h6e9494a_0        16.9 MB
>>>  conda-forge
>>>     curl-7.78.0                |       h7bc2e8c_0         133 KB
>>>     expat-2.4.1                |       he49afe7_0         143 KB
>>>  conda-forge
>>>     fontconfig-2.13.1          |    h10f422b_1005         271 KB
>>>  conda-forge
>>>     freetype-2.10.4            |       h4cff582_1         890 KB
>>>  conda-forge
>>>     freexl-1.0.6               |       h0d85af4_0          42 KB
>>>  conda-forge
>>>     gdal-3.0.2                 |   py39ha6ec53f_1         1.1 MB
>>>     geos-3.8.0                 |       hb1e8313_0         815 KB
>>>     geotiff-1.6.0              |       h02c1893_0         120 KB
>>>     gettext-0.21.0             |       h7535e17_0         2.6 MB
>>>     giflib-5.2.1               |       hbcb3906_2          71 KB
>>>  conda-forge
>>>     glib-2.69.1                |       hdf23fa2_0         2.7 MB
>>>     hdf4-4.2.13                |       h39711bb_2         682 KB
>>>     hdf5-1.10.6                |nompi_hc5d9132_1114         3.1 MB
>>>  conda-forge
>>>     icu-64.2                   |       h6de7cb9_1        12.3 MB
>>>  conda-forge
>>>     jbig-2.1                   |    h0d85af4_2003          42 KB
>>>  conda-forge
>>>     jpeg-9d                    |       hbcb3906_0         250 KB
>>>  conda-forge
>>>     json-c-0.13.1              |    h575e443_1002          66 KB
>>>  conda-forge
>>>     kealib-1.4.14              |       h31dd65d_2         156 KB
>>>  conda-forge
>>>     krb5-1.19.2                |       hcfbf3a7_0         1.3 MB
>>>  conda-forge
>>>     lerc-2.2.1                 |       h046ec9c_0         164 KB
>>>  conda-forge
>>>     libblas-3.9.0              |12_osx64_openblas          12 KB
>>>  conda-forge
>>>     libcblas-3.9.0             |12_osx64_openblas          12 KB
>>>  conda-forge
>>>     libcurl-7.78.0             |       hb8e4fae_0         311 KB
>>>     libcxx-12.0.1              |       habf9029_0         1.1 MB
>>>  conda-forge
>>>     libdap4-3.19.1             |       h3d3e54a_0         1.1 MB
>>>     libdeflate-1.7             |       h35c211d_5          67 KB
>>>  conda-forge
>>>     libedit-3.1.20191231       |       h0678c8f_2         103 KB
>>>  conda-forge
>>>     libev-4.33                 |       haf1e3a3_1          99 KB
>>>  conda-forge
>>>     libgdal-3.0.2              |       ha1444b2_1        10.4 MB
>>>     libgfortran-5.0.0          |9_3_0_h6c81a4c_23          19 KB
>>>  conda-forge
>>>     libgfortran5-9.3.0         |      h6c81a4c_23         1.7 MB
>>>  conda-forge
>>>     libiconv-1.16              |       haf1e3a3_0         1.3 MB
>>>  conda-forge
>>>     libkml-1.3.0               |    h88bc94a_1012         473 KB
>>>  conda-forge
>>>     liblapack-3.9.0            |12_osx64_openblas          12 KB
>>>  conda-forge
>>>     libnetcdf-4.6.1            |       hfd9a460_4         782 KB
>>>     libnghttp2-1.43.0          |       h6f36284_1         867 KB
>>>  conda-forge
>>>     libopenblas-0.3.18         |openmp_h3351f45_0         9.0 MB
>>>  conda-forge
>>>     libpng-1.6.37              |       h7cec526_2         313 KB
>>>  conda-forge
>>>     libpq-12.2                 |       h1b4eb34_1         2.0 MB
>>>     libspatialite-4.3.0a       |       h5142b36_0         2.1 MB
>>>     libssh2-1.10.0             |       h52ee1ee_2         221 KB
>>>  conda-forge
>>>     libtiff-4.3.0              |       h1167814_1         621 KB
>>>  conda-forge
>>>     libwebp-base-1.2.1         |       h0d85af4_0         692 KB
>>>  conda-forge
>>>     libxml2-2.9.10             |       h53d96d6_0         1.2 MB
>>>  conda-forge
>>>     llvm-openmp-12.0.1         |       hda6cdc1_1         287 KB
>>>  conda-forge
>>>     lz4-c-1.9.3                |       he49afe7_1         155 KB
>>>  conda-forge
>>>     numpy-1.21.4               |   py39h7eed0ac_0         5.8 MB
>>>  conda-forge
>>>     openjpeg-2.3.1             |       h6cbf5cd_3         373 KB
>>>  conda-forge
>>>     openssl-1.1.1l             |       h0d85af4_0         1.9 MB
>>>  conda-forge
>>>     pcre-8.45                  |       he49afe7_0         220 KB
>>>  conda-forge
>>>     pixman-0.38.0              |    h01d97ff_1003         611 KB
>>>  conda-forge
>>>     poppler-0.89.0             |       h9de36d4_1         1.6 MB
>>>  conda-forge
>>>     poppler-data-0.4.11        |       hd8ed1ab_0         3.6 MB
>>>  conda-forge
>>>     postgresql-12.2            |       h1b4eb34_1         3.3 MB
>>>     proj-6.2.1                 |       h773a61f_0        10.0 MB
>>>  conda-forge
>>>     python_abi-3.9             |           2_cp39           4 KB
>>>  conda-forge
>>>     tiledb-2.3.4               |       h8370e7a_0         2.9 MB
>>>  conda-forge
>>>     xerces-c-3.2.3             |       h8f8adb3_0         1.5 MB
>>>  conda-forge
>>>     zstd-1.5.0                 |       h582d3a0_0         583 KB
>>>  conda-forge
>>>                                            Total:       133.2 MB
>>> The following NEW packages will be INSTALLED:
>>>   boost-cpp          conda-forge/osx-64::boost-cpp-1.72.0-hdf9ef73_0
>>>   bzip2              conda-forge/osx-64::bzip2-1.0.8-h0d85af4_4
>>>   c-ares             conda-forge/osx-64::c-ares-1.18.1-h0d85af4_0
>>>   cairo              conda-forge/osx-64::cairo-1.16.0-hec6a9b0_1003
>>>   cfitsio            conda-forge/osx-64::cfitsio-3.470-h01dc385_7
>>>   curl               pkgs/main/osx-64::curl-7.78.0-h7bc2e8c_0
>>>   expat              conda-forge/osx-64::expat-2.4.1-he49afe7_0
>>>   fontconfig         conda-forge/osx-64::fontconfig-2.13.1-h10f422b_1005
>>>   freetype           conda-forge/osx-64::freetype-2.10.4-h4cff582_1
>>>   freexl             conda-forge/osx-64::freexl-1.0.6-h0d85af4_0
>>>   gdal               pkgs/main/osx-64::gdal-3.0.2-py39ha6ec53f_1
>>>   geos               pkgs/main/osx-64::geos-3.8.0-hb1e8313_0
>>>   geotiff            pkgs/main/osx-64::geotiff-1.6.0-h02c1893_0
>>>   gettext            pkgs/main/osx-64::gettext-0.21.0-h7535e17_0
>>>   giflib             conda-forge/osx-64::giflib-5.2.1-hbcb3906_2
>>>   glib               pkgs/main/osx-64::glib-2.69.1-hdf23fa2_0
>>>   hdf4               pkgs/main/osx-64::hdf4-4.2.13-h39711bb_2
>>>   hdf5               conda-forge/osx-64::hdf5-1.10.6-nompi_hc5d9132_1114
>>>   icu                conda-forge/osx-64::icu-64.2-h6de7cb9_1
>>>   jbig               conda-forge/osx-64::jbig-2.1-h0d85af4_2003
>>>   jpeg               conda-forge/osx-64::jpeg-9d-hbcb3906_0
>>>   json-c             conda-forge/osx-64::json-c-0.13.1-h575e443_1002
>>>   kealib             conda-forge/osx-64::kealib-1.4.14-h31dd65d_2
>>>   krb5               conda-forge/osx-64::krb5-1.19.2-hcfbf3a7_0
>>>   lerc               conda-forge/osx-64::lerc-2.2.1-h046ec9c_0
>>>   libblas            conda-forge/osx-64::libblas-3.9.0-12_osx64_openblas
>>>   libcblas           conda-forge/osx-64::libcblas-3.9.0-12_osx64_openblas
>>>   libcurl            pkgs/main/osx-64::libcurl-7.78.0-hb8e4fae_0
>>>   libdap4            pkgs/main/osx-64::libdap4-3.19.1-h3d3e54a_0
>>>   libdeflate         conda-forge/osx-64::libdeflate-1.7-h35c211d_5
>>>   libedit            conda-forge/osx-64::libedit-3.1.20191231-h0678c8f_2
>>>   libev              conda-forge/osx-64::libev-4.33-haf1e3a3_1
>>>   libgdal            pkgs/main/osx-64::libgdal-3.0.2-ha1444b2_1
>>>   libgfortran
>>>  conda-forge/osx-64::libgfortran-5.0.0-9_3_0_h6c81a4c_23
>>>   libgfortran5       conda-forge/osx-64::libgfortran5-9.3.0-h6c81a4c_23
>>>   libiconv           conda-forge/osx-64::libiconv-1.16-haf1e3a3_0
>>>   libkml             conda-forge/osx-64::libkml-1.3.0-h88bc94a_1012
>>>   liblapack
>>>  conda-forge/osx-64::liblapack-3.9.0-12_osx64_openblas
>>>   libnetcdf          pkgs/main/osx-64::libnetcdf-4.6.1-hfd9a460_4
>>>   libnghttp2         conda-forge/osx-64::libnghttp2-1.43.0-h6f36284_1
>>>   libopenblas
>>>  conda-forge/osx-64::libopenblas-0.3.18-openmp_h3351f45_0
>>>   libpng             conda-forge/osx-64::libpng-1.6.37-h7cec526_2
>>>   libpq              pkgs/main/osx-64::libpq-12.2-h1b4eb34_1
>>>   libspatialite      pkgs/main/osx-64::libspatialite-4.3.0a-h5142b36_0
>>>   libssh2            conda-forge/osx-64::libssh2-1.10.0-h52ee1ee_2
>>>   libtiff            conda-forge/osx-64::libtiff-4.3.0-h1167814_1
>>>   libwebp-base       conda-forge/osx-64::libwebp-base-1.2.1-h0d85af4_0
>>>   libxml2            conda-forge/osx-64::libxml2-2.9.10-h53d96d6_0
>>>   llvm-openmp        conda-forge/osx-64::llvm-openmp-12.0.1-hda6cdc1_1
>>>   lz4-c              conda-forge/osx-64::lz4-c-1.9.3-he49afe7_1
>>>   numpy              conda-forge/osx-64::numpy-1.21.4-py39h7eed0ac_0
>>>   openjpeg           conda-forge/osx-64::openjpeg-2.3.1-h6cbf5cd_3
>>>   pcre               conda-forge/osx-64::pcre-8.45-he49afe7_0
>>>   pixman             conda-forge/osx-64::pixman-0.38.0-h01d97ff_1003
>>>   poppler            conda-forge/osx-64::poppler-0.89.0-h9de36d4_1
>>>   poppler-data       conda-forge/noarch::poppler-data-0.4.11-hd8ed1ab_0
>>>   postgresql         pkgs/main/osx-64::postgresql-12.2-h1b4eb34_1
>>>   proj               conda-forge/osx-64::proj-6.2.1-h773a61f_0
>>>   python_abi         conda-forge/osx-64::python_abi-3.9-2_cp39
>>>   tiledb             conda-forge/osx-64::tiledb-2.3.4-h8370e7a_0
>>>   xerces-c           conda-forge/osx-64::xerces-c-3.2.3-h8f8adb3_0
>>>   zstd               conda-forge/osx-64::zstd-1.5.0-h582d3a0_0
>>> The following packages will be UPDATED:
>>>   ca-certificates    pkgs/main::ca-certificates-2021.7.5-h~ -->
>>> conda-forge::ca-certificates-2021.10.8-h033912b_0
>>>   certifi            pkgs/main::certifi-2021.5.30-py39hecd~ -->
>>> conda-forge::certifi-2021.10.8-py39h6e9494a_1
>>>   conda              pkgs/main::conda-4.10.3-py39hecd8cb5_0 -->
>>> conda-forge::conda-4.11.0-py39h6e9494a_0
>>>   libcxx                         pkgs/main::libcxx-10.0.0-1 -->
>>> conda-forge::libcxx-12.0.1-habf9029_0
>>>   openssl              pkgs/main::openssl-1.1.1k-h9ed2024_0 -->
>>> conda-forge::openssl-1.1.1l-h0d85af4_0
>>> Proceed ([y]/n)? y
>>> Downloading and Extracting Packages
>>> bzip2-1.0.8          | 155 KB    |
>>> | 100%
>>> fontconfig-2.13.1    | 271 KB    |
>>> | 100%
>>> krb5-1.19.2          | 1.3 MB    |
>>> | 100%
>>> gdal-3.0.2           | 1.1 MB    |
>>> | 100%
>>> freetype-2.10.4      | 890 KB    |
>>> | 100%
>>> hdf5-1.10.6          | 3.1 MB    |
>>> | 100%
>>> proj-6.2.1           | 10.0 MB   |
>>> | 100%
>>> libblas-3.9.0        | 12 KB     |
>>> | 100%
>>> lerc-2.2.1           | 164 KB    |
>>> | 100%
>>> libgfortran-5.0.0    | 19 KB     |
>>> | 100%
>>> lz4-c-1.9.3          | 155 KB    |
>>> | 100%
>>> libiconv-1.16        | 1.3 MB    |
>>> | 100%
>>> icu-64.2             | 12.3 MB   |
>>> | 100%
>>> libedit-3.1.20191231 | 103 KB    |
>>> | 100%
>>> libxml2-2.9.10       | 1.2 MB    |
>>> | 100%
>>> python_abi-3.9       | 4 KB      |
>>> | 100%
>>> numpy-1.21.4         | 5.8 MB    |
>>> | 100%
>>> conda-4.11.0         | 16.9 MB   |
>>> | 100%
>>> ca-certificates-2021 | 139 KB    |
>>> | 100%
>>> poppler-0.89.0       | 1.6 MB    |
>>> | 100%
>>> liblapack-3.9.0      | 12 KB     |
>>> | 100%
>>> expat-2.4.1          | 143 KB    |
>>> | 100%
>>> boost-cpp-1.72.0     | 19.1 MB   |
>>> | 100%
>>> glib-2.69.1          | 2.7 MB    |
>>> | 100%
>>> libgdal-3.0.2        | 10.4 MB   |
>>> | 100%
>>> libspatialite-4.3.0a | 2.1 MB    |
>>> | 100%
>>> libnetcdf-4.6.1      | 782 KB    |
>>> | 100%
>>> openssl-1.1.1l       | 1.9 MB    |
>>> | 100%
>>> hdf4-4.2.13          | 682 KB    |
>>> | 100%
>>> libcurl-7.78.0       | 311 KB    |
>>> | 100%
>>> jpeg-9d              | 250 KB    |
>>> | 100%
>>> openjpeg-2.3.1       | 373 KB    |
>>> | 100%
>>> libwebp-base-1.2.1   | 692 KB    |
>>> | 100%
>>> c-ares-1.18.1        | 100 KB    |
>>> | 100%
>>> libdap4-3.19.1       | 1.1 MB    |
>>> | 100%
>>> libpng-1.6.37        | 313 KB    |
>>> | 100%
>>> xerces-c-3.2.3       | 1.5 MB    |
>>> | 100%
>>> libdeflate-1.7       | 67 KB     |
>>> | 100%
>>> geos-3.8.0           | 815 KB    |
>>> | 100%
>>> giflib-5.2.1         | 71 KB     |
>>> | 100%
>>> libgfortran5-9.3.0   | 1.7 MB    |
>>> | 100%
>>> libssh2-1.10.0       | 221 KB    |
>>> | 100%
>>> libcxx-12.0.1        | 1.1 MB    |
>>> | 100%
>>> libopenblas-0.3.18   | 9.0 MB    |
>>> | 100%
>>> geotiff-1.6.0        | 120 KB    |
>>> | 100%
>>> libnghttp2-1.43.0    | 867 KB    |
>>> | 100%
>>> zstd-1.5.0           | 583 KB    |
>>> | 100%
>>> libtiff-4.3.0        | 621 KB    |
>>> | 100%
>>> libkml-1.3.0         | 473 KB    |
>>> | 100%
>>> libcblas-3.9.0       | 12 KB     |
>>> | 100%
>>> tiledb-2.3.4         | 2.9 MB    |
>>> | 100%
>>> llvm-openmp-12.0.1   | 287 KB    |
>>> | 100%
>>> gettext-0.21.0       | 2.6 MB    |
>>> | 100%
>>> curl-7.78.0          | 133 KB    |
>>> | 100%
>>> pixman-0.38.0        | 611 KB    |
>>> | 100%
>>> json-c-0.13.1        | 66 KB     |
>>> | 100%
>>> cairo-1.16.0         | 1.3 MB    |
>>> | 100%
>>> postgresql-12.2      | 3.3 MB    |
>>> | 100%
>>> jbig-2.1             | 42 KB     |
>>> | 100%
>>> certifi-2021.10.8    | 145 KB    |
>>> | 100%
>>> libev-4.33           | 99 KB     |
>>> | 100%
>>> libpq-12.2           | 2.0 MB    |
>>> | 100%
>>> poppler-data-0.4.11  | 3.6 MB    |
>>> | 100%
>>> cfitsio-3.470        | 1.3 MB    |
>>> | 100%
>>> freexl-1.0.6         | 42 KB     |
>>> | 100%
>>> pcre-8.45            | 220 KB    |
>>> | 100%
>>> kealib-1.4.14        | 156 KB    |
>>> | 100%
>>> Preparing transaction: done
>>> Verifying transaction: done
>>> Executing transaction: done
>>> (base) ➜  ~ gdalinfo --version
>>>   Referenced from: /Users/idan.miara/opt/miniconda3/lib/libgdal.26.dylib
>>>   Reason: image not found
>>> [1]    76584 abort      gdalinfo --version
>>> (base) ➜  ~
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> M.Sc. Geogr. Daniel Scheffler
>> Helmholtz Centre Potsdam
>> GFZ German Research Centre For Geosciences
>> Department 1 - Geodesy and Remote Sensing
>> Section 1.4  - Remote Sensing
>> Telegrafenberg, 14473 Potsdam, Germany
>> Phone:  +49 (0)331/288-1198
>> e-mail: daniel.scheffler at gfz-potsdam.de
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/88f7be95/attachment-0001.html>
