[gdal-dev] mosaicking files with partial overlap and binary mask
Patrick Young patrick.mckendree.young at gmail.com
Wed Jan 27 15:02:18 PST 2021
Hi Daniele,
Even added this functionality to VRTs just recently, see
https://lists.osgeo.org/pipermail/gdal-dev/2020-December/053178.html
I think it is slated for GDAL 3.3 but you could always build the bleeding
edge.
Patrick
On Wed, Jan 27, 2021 at 3:50 AM Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi list,
> I have some TIFF datasets with partially overlapping edges and embedded
> binary masks to keep into account which parts along the edges should be
> masked out.
> When showing all the images on QGIS it looks good since the binary mask do
> its job by making the "black/white" overlapping edge masked out.
> Now I need to create a single TIF from all of these images.
> I have tried with gdalbuildvrt but it doesn't produce good result.
> Checking the doc I saw this:
> *If there is some amount of spatial overlapping between files [...]
> currently, alpha channel is not taken into account to do alpha compositing
> (so a source with alpha=0 appearing on top of another source will override
> is content). This might be changed in later versions.  *
> So I think it's expected and I have switched to gdal_merge.py.
> It works better since it does alpha compositing but it looks like the
> result doesn't preserve the binary mask which I still need since I have M
> groups of N files which I need to process in 2 passes:
> - the inner group of N files get merged using the binary mask to a bigger
> file.
> - all the M bigger files get mosaicked again to a single huge file.
> I will spend some more time in testing different attempts.
> In the meantime, do you have any suggestion or past experience on how to
> deal with that?
> Side note: I have vague memory of gdal_merge being somehow memory bounded,
> throwing memory allocation errors when trying to compose big images. This
> is why in the past I was using gdalbuildvrt to do composition (without
> overlapping).
> Thanks in advance.
> Regards,
> Daniele
> Regards,
> Daniele Romagnoli
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210127/3a04106c/attachment.html>
