[gdal-dev] mosaicking files with partial overlap and binary mask
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Jan 28 01:12:21 PST 2021
Hi Patrick,
nice!
Thanks for the feedback.
Do you have any info about eventual backports to previous versions?
Regards,
Daniele
On Thu, Jan 28, 2021 at 12:02 AM Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> Hi Daniele,
> Even added this functionality to VRTs just recently, see
> https://lists.osgeo.org/pipermail/gdal-dev/2020-December/053178.html
> I think it is slated for GDAL 3.3 but you could always build the bleeding
> edge.
> Patrick
> On Wed, Jan 27, 2021 at 3:50 AM Daniele Romagnoli <
> daniele.romagnoli at geo-solutions.it> wrote:
>> Hi list,
>> I have some TIFF datasets with partially overlapping edges and embedded
>> binary masks to keep into account which parts along the edges should be
>> masked out.
>> When showing all the images on QGIS it looks good since the binary mask
>> do its job by making the "black/white" overlapping edge masked out.
>> Now I need to create a single TIF from all of these images.
>> I have tried with gdalbuildvrt but it doesn't produce good result.
>> Checking the doc I saw this:
>> *If there is some amount of spatial overlapping between files [...]
>> currently, alpha channel is not taken into account to do alpha compositing
>> (so a source with alpha=0 appearing on top of another source will override
>> is content). This might be changed in later versions.  *
>> So I think it's expected and I have switched to gdal_merge.py.
>> It works better since it does alpha compositing but it looks like the
>> result doesn't preserve the binary mask which I still need since I have M
>> groups of N files which I need to process in 2 passes:
>> - the inner group of N files get merged using the binary mask to a bigger
>> file.
>> - all the M bigger files get mosaicked again to a single huge file.
>> I will spend some more time in testing different attempts.
>> In the meantime, do you have any suggestion or past experience on how to
>> deal with that?
>> Side note: I have vague memory of gdal_merge being somehow memory
>> bounded, throwing memory allocation errors when trying to compose big
>> images. This is why in the past I was using gdalbuildvrt to do composition
>> (without overlapping).
>> Thanks in advance.
>> Regards,
>> Daniele
>> Regards,
>> Daniele Romagnoli
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Daniele Romagnoli
>> Senior Software Engineer
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:      +39 0584 1660272
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
GeoSolutions S.A.S.
Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210128/1f7e0d46/attachment.html>
